Custom Isolines Fails
Hi All,
In my project I want to have isolines plotted at regular intervals (i.e. 100, 200, 300).  In the specific set of data I’m using, the isolines fail to generate properly when using a Kriging style of interpolation.
Attached you will find a test project with the dataset in question.  Simply run the program and click the Krig button.  This will generate a map with isolines plotted using the min/max depth and 25 ClassBreaks so we get awkward intervals (59.375m).  Next, select the Interval Isolines radio button and then Krig button again.  This method creates intervals at 100m between the min/max depths.  You will see the isolines fail to calculate properly and we only get a couple blips on the screen.  The two images are shown below.
If you run using the IDW method, you don’t get the same behavior and isolines are more or less calculated over the limited area the search radius parameter allows.
Damian
IsolinesInSphericalMercator.zip (1.11 MB)
Hi Damian,
 Thanks for providing the detailed information, we are still working on this now, I guess the solution should be avaialbe soon. Sorry for the delay.
Thanks Johnny,
 I am holding up a release for this issue, so would be great if you can find a solution soon.
 Damian
Hi Damian,
 We have fixed the Krig bug, would you please get the latest version 7.0.38.0 or 7.0.0.38(still in build, will be available in hours)
 Hope it helps
 Summer
Summer,
 I see no change with the 7.0.0.38 build.
 As per my other post, I see unmanaged dependencies is still at 7.0.0.35.  Don’t think that should matter for this functionality though.
 Damian
Hi Damian,
The reason for this is that when we check in the build process for 7.0.38.0 and 7.0.0.38 has already started, so the check in didn’t take effect, so it will be validated in 7.0.39.0 or 7.0.0.39 and later, about unmanaged dependencies, it will be replied in post thinkgeo.com/forums/MapSuite/tabid/143/aft/11390/Default.aspx, would you please check it?
Following is a result image of the newst dll:
 Sorry for the inconvenience
Summer
Seems to be working with 7.0.0.45.
 Damian
Great,
 Feel free to let us know if you have any questions.
 Jack
