Custom zoom levels and level based styles revisited
I'm attempting to set the display of labels in a subset of zoom levels. I add the TextSyle to (e.g.) ZoomLevel # 11, and applies this until zoom level # 20. It didn't work ! The labels we're clearly displayed on all levels.
I then got suspicious. I'm using customized map zoom level scales (to enable zooming in closely), and thought that these we're automatically applied to the map layers on a zoom level _index_ basis. I.e. map.ZoomLevelSet.ZoomLevel01 equals layer.ZoomLevelSet.ZoomLevel01 etc. This appeared to be a wrong assumption on my part.
It seems that layer zoom levels and map zoom levels are independent entities, and matched on their scale values when applied.
Now, after setting custom map zoom level scales, after adding all my layers to the map, when I apply the map scales to each layer, the label display finally works as expected:
    Sub ApplyMapZoomLevelScalesToLayers(ByVal Map1 As Map)
        For Each ovl In Map1.CustomOverlays
            If TypeOf ovl Is LayerOverlay Then
                For Each lyr In DirectCast(ovl, LayerOverlay).Layers
                    If TypeOf lyr Is FeatureLayer Then
                        With DirectCast(lyr, FeatureLayer)
                            For i = 0 To .ZoomLevelSet.GetZoomLevels.Count - 1
                                Try
                                    .ZoomLevelSet.GetZoomLevels(i).Scale = Map1.ZoomLevelSet.GetZoomLevels(i).Scale
                                Catch ex As Exception
                                End Try
                            Next
                        End With
                    End If
                Next
            End If
        Next
    End Sub
Is this WAD ? Why would one want to set zoom level scales independently on each layer as opposed to on the interactive map ?
Would it not be better to use the map zoom level scales for all layers, at least when the latter haven't been specifically defined ?
TIA
Using 5.5 build 111, by the way.
Hi TIA,
 Thank you for you suggestions, we may one day do this kind of enhancements.
 Best Regards,
 Edgar
TIA,
We used to think about synchronizing the layers’ zoomlevels with map’s zoomlevel and finally decided to keep the current way. First because it needs more work and some users might not like it. Second we want to keep a layer the same behavior whenever it is, so no matter I put a layer to map1 or map2, to Desktop Edition, Web Edition or WMS server, the style is exactly the same. This way I think is with the least surprise and the behavior is easier to predict.
As you’ve found out, you can work it around by resetting the zoomlevels of each layer. Another workaround is creating a new class inheriting the feature layer; no override is needed except in the new class’s constructor we just set this.ZoomLevelSet to the new one. In this way we don’t need to add extra method to the code and just update the new feature layer whenever we want to update the zoomlevels.
Edgar
