Data Security of Geometry Data
I was wondering how i could protect my data to prevent anyone gaining access to the database.
Is this possible using web services ? and can the web services be used with the "Map Suite Web Edition" ?
Hi Gregory,
 How will you use your data with our map control?
 I am not sure your scenario, could you have some more detail description?
I perform a Spatial query on a Point Feature dataset.
 I then use the column values from that and then show them in various overlays on a map
Not a Dataset a SQL2008 database with Geometry column
Gregory,
 If you did spatial query with your database, that only connect your database in server side, and in client side the user cannot know what is your connection string.
 Which step you think may let someone gaining access to your database?
