'DBF file is being used by another process' error during the search
My application throws an error wnen searching through a shape file:
"The process cannot access the file '...\xxx.dbf' because it is being used by another process."
Here is my code:
ShapeFileFeatureLayer allProperties = new ShapeFileFeatureLayer(context.Server.MapPath("~/.../xxx.shp"));
allProperties.Open();
DataTable dt = allProperties.QueryTools.ExecuteQuery("SELECT PropertyNa, Longitude, Latitude, StatusID, DrillHole, Featured FROM All WHERE PropertyID IN (" + propertyIds + ") ");
allProperties.Close();
I guess, it happened because the search through a shape file takes some times and this file is locked during this time (because Open/Close methods) . When other search is executing and file is locked, an error is thrown.
Is any way not to lock a file during search? How can I handle this error?
Igor
Hi Igor,
Is this code block in a multi-thread scope?If so, please try to add a locker, or you can send a sample that could recreate the issue to us to solve it efficiency.
Edgar
Hi Edgar,
Thank you for your reply. I don't use multi-treading in my application. We got this problem when publish the application on a production server and a lot of clients start searching at the same time. It errors occurs only when there are several searches at the same time.
Does Open() method lock the dbf-file?
Below is complete code of my function:
private void addSearchResult()
try
string propertyIds;
if (!String.IsNullOrEmpty(hdnPropertyIds.Value))
propertyIds = hdnPropertyIds.Value;
else if (!String.IsNullOrEmpty(Request.QueryString["pid"]))
propertyIds = Request.QueryString["pid"];
else
return;
ShapeFileFeatureLayer allProperties = new ShapeFileFeatureLayer(Server.MapPath("~/.../xxx.shp"));
DataTable dt = allProperties.QueryTools.ExecuteQuery("SELECT PropertyNa, Longitude, Latitude, StatusID, StatusName, TypeName, DrillHole, Featured FROM All WHERE PropertyID IN (" + propertyIds + ") ");
LayerOverlay customOverlay = (LayerOverlay)Map1.CustomOverlays["Properties"];
InMemoryFeatureLayer layer = (InMemoryFeatureLayer)customOverlay.Layers["SearchResults"];
LayerOverlay customLabelOverlay = (LayerOverlay)Map1.CustomOverlays["PropertyLabels"];
InMemoryFeatureLayer labelLayer = (InMemoryFeatureLayer)customLabelOverlay.Layers["SearchResultsLabel"];
layer.InternalFeatures.Clear();
labelLayer.InternalFeatures.Clear();
RectangleShape extent = null;
double x = 0, y = 0;
foreach (DataRow p in dt.Rows)
x = Convert.ToDouble(p["Longitude"].ToString());
y = Convert.ToDouble(p["Latitude"].ToString());
Feature f = new PointShape(x, y).GetFeature();
f.ColumnValues.Add("PropertyNa", p["PropertyNa"].ToString());
f.ColumnValues.Add("StatusName", p["StatusName"].ToString());
f.ColumnValues.Add("TypeName", p["TypeName"].ToString());
f.ColumnValues.Add("Featured", p["Featured"].ToString());
f.ColumnValues.Add("Longitude", p["Longitude"].ToString());
f.ColumnValues.Add("Latitude", p["Latitude"].ToString());
if (extent == null)
extent = f.GetBoundingBox();
else
extent.ExpandToInclude(f.GetBoundingBox());
layer.InternalFeatures.Add(f);
labelLayer.InternalFeatures.Add(f);
catch (Exception exp)
sendEmail("home page mapper error", "addSearchResult(): " + exp.Message);
Igor,
 The Open method will not lock the file, besides, we tried to create a sample like yours to recreate the scenario but failed, could you please send your sample to us to have a test? Maybe we can find out the problem there.
 Edgar
Thank you, Edgar! I've just sent a light version of my app to ThinkGeo Customer Portal
Hello Igor,
 Please check the ticket for more details.
