Hi, Liam
Thanks for your sample project.
There are two problems in your codes.
One is setting the virtual path which is the relative path and it can’t start with “~”. In your sample, please set it like the code below:
liftOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = new WebImage("i/home_32x32.png", 80, 80);
Or
liftOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = new WebImage("../i/home_32x32.png", 80, 80);
In the “Markers” folder of our installed samples, and there are many samples related with how to set the virtual path for the web image. Please have a look at it.
Another problem is that even though you have set the dimension of web image is 80*80 (the original is 32*32) and there is no change for the image. Yes, this problems is related with the recent change comes from the post you have mentioned.
If you want to fix that, adding the script codes below before the closing body tag.
<script type="text/javascript">
function ConvertJsonToIcon(json, imgRootPath) {
var size;
if (json.w == 0 && json.h == 0) {
size = null;
else {
size = new OpenLayers.Size(json.w, json.h);
if (json.url == '') {
json.url = imgRootPath + 'theme/default/img/marker_blue.gif';
var icon = new OpenLayers.Icon(json.url, size);
if (size) {
icon.offset = new OpenLayers.Pixel(CalculateOffset(json.ox, size.w), CalculateOffset(json.oy, size.h));
return icon;
</script>
If you still have issues then please let us know.
Khalil
