Delayed Start on Networks with no Internet Access
I am running my application on a workstation that is connected to two LANs.  These LANs do not have Internet access.
When the application is started it is running, but the UI does not appear on the desktop and is delayed approximatley 80-90 seconds while the MapSuite dll's are loaded/initialized.
When one of the LAN's is disabled the delay is about 40 seconds before the application UI appears.  When both LANs are disabled the application starts and the UI appears immediately.
It would appear that there is something in the MapSuite dll's that sense an enabled network and attempt to reach some website.
Is there some Internet access that is being attempted and if so how would I disable that feature?
Dennis
Hi Dennis,
Are you using the HowDoISample? If so, please remove this one from your UI.
If not, could you please attach your sample here? The MapSuite dlls won't attempt to reach the network normally.
Edgar
Edgar,
No, I am not using the HowDoISample.
To test this I created a new VS2010 project with a WpfMap and the load of one layer.  This very simple application also took 80-90 seconds to load.
Are there any cases where MapSuite attempts to connect to the Internet or is looking for a particular URL on the network?
What about external maps such as Bing, Yahoo, etc?  I'm not using any of those.
Dennis
I cannot recreate the issue on my side, what layer are you loading and what’s the version you are using?
 Edgar
I'll have to work on getting you a test application tomorrow so that all you'll have to do is compile and run it.
Now remember that this delay only surfaces when the workstation is connected to a local area network that does not have Internet access.  It appears to be sensing that there is a network and is therefore attempting to access some URL.
If the network, under Windows Control Panel->Network, is disabled you will not see this problem.
Dennis
Thanks Dennis, hope the sample you provide will recreate the issue.
 Edgar
Edgar,
How can I send you  a VS2010 project?  The maximum file size to upload on the form is 500kb.
Dennis
You can send it to forumsupport@thinkgeo.com
 Edgar
Just emailed the project.
Dennis
Thanks for the sample Dennis, I can recreate this on my side, the reason is that we used the bing maps logo from the network, and we’ve changed it to load the local image a month ago, please get the 6.0.88.0 and have a try.
 Hope it helps,
 Edgar
Thanks for the info Edgar.  I will download that release as soon as I can.
Dennis
Hello Dennis,
 You are welcome, feel free to let us know if you meet any problem.
Gary,
Edgar instructed me to download V6.0.88.0, but I do not see that anywhere on the MapSuite WeSite.
Where/how do I get this version?
Dennis
Hello Dennis,
 Edgar means we have changed to load the local image a month ago, and in that time, the version is 6.0.88.0, so you can get 6.0.88.0 or later(the newest is 6.0.130.0) and have a try.
 You can visit helpdesk.thinkgeo.com to get it.
Gary/Edgar,
Are you referring to a Production Build or a Development build that I should download.
Dennis
Hello Dennis,
 You can try Development build, it has more function, more bug fix than production version, but production is more stable than development version because we will update production version until we confirmed any change has no problem.
 So you can try the development first, and if it’s ok, change to production version or not, it’s both ok.
Gary,
I tried the Daily Production Build 6.0.0.130, but my issue still persisted.
I tried the Daily Development Build 6.0.130.0 and my issue was resolved.
Do you know when the Web Access issue will be available in a Daily Production Build?  I'd rather use a Production Build because it has been tested.
Dennis
Dennis,
 Please get the 6.0.0.134 and have a try.
 Edgar
Edgar,
Did you mean 6.0.0.133?  I don't see a 6.0.0.134.
Dennis
Dennis,
 6.0.0.134 is not available until tomorrow. Please wait for it.
 Edgar
