Delete vertex causes null pointer excection
Deleting 2nd to last point causes a null pointer exception to be thrown. I also duplicated this issue using https://github.com/ThinkGeo/DrawEditFeaturesSample-ForAndroid with the latest 10.5.x android code. Using the sample above a placed a line with 2 points and then went to edit mode and attempted to delete one of the points
I have not verified this but I was told that this issue also occurs in the iOS version as well.
Hi Richard,
Thanks to let us know it.
I download the sample also, upgrade each package to the latest version. Because my installed android version is 9.0(pie), so I just upgrade the version of project.
Then I draw a line first:
Go back to Edit mode:
Double click the 2nd vertex:
It looks exception not been thrown there.
Then I back to pan mode and application still works.
If I missed any step please let me know.
I am not very accurate when trying to do double taps.
The circled vertex that is under that image is the one I am trying to delete and I am double tapping in that area – when I see that I didn’t actually delete the vertex I immediately try again. Sometime it does behave exactly as I would expect, but I can very reliably make it happen. I am using android version 8.1
Hi Richard,
Thanks to let us know how to reproduce it, in fact I don’t know what’s the control point there, it looks resize, move and rotate control point is in other position, I think if a vertex is covered by control point you should want to handle it by other way, because the control point will block your operation to vertex.
And MapSuite 8 had stopped to get support, so even we reproduce it we cannot fix it.
Could you please upgrade your version to 9 or 10? Version 9 is nearly the same and version 10 have big changes in dll references.
Sorry for clarification I am on Thinkgeo android version 10.5.x . My Android os version is 8.1
Hi Richard,
Thanks to point that.
But it looks I hadn’t found the operation button so I cannot reproduce it:
I had set like this:
androidMap.EditOverlay.CanAddVertex = true;
androidMap.EditOverlay.CanDrag = true;
androidMap.EditOverlay.CanRemoveVertex = true;
androidMap.EditOverlay.CanReshape = true;
androidMap.EditOverlay.CanResize = true;
androidMap.EditOverlay.CanRotate = true;
