Deleting from InMemoryFeatureLayer
 Hello, I'm new to working with ThinkGeo. I'm working on an existing application and have run into some issues. I have a bunch of vertex locations which I need to translate to the ThinkGeo map display. Previously I had a List of InMemoryFeatureLayer and gave each polygon it's own default area and line styles within their own layer.
It worked but it seemed like a bad idea but it let me prototype the other features of the application. Now that the application is constructed I'm going back to enchance the ThinkGeo portions. First I created a custom style which draws based on the properties of my polygons. Doing this allowed me to get rid of my individual InMemoryFeatureLayer's and store all the features using a single layer.
Everything displays nicely on the map but when I try to remove a feature using it's ID it remains in the InternalFeatures of my layer and I can't figure out why. I've tested the id I'm asking to remove with the feature.Id and they match. Here's a condensed bit of code:
// Set Up Everything in ctor
            _mapObstacleLayer = new InMemoryFeatureLayer();
            _mapObstacleOverlay = new LayerOverlay();
            _mapObstacleStyle = new ObstacleStyle();
            _mapObstacleLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(_mapObstacleStyle);
            _mapObstacleLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            _mapObstacleOverlay.Layers.Add(OBSTACLE_LAYER, _mapObstacleLayer);
            _map.Overlays.Add(OBSTACLE_OVERLAY, _mapObstacleOverlay);
I then add my obstacles in a foreach
foreach(Obstacle obstacle in obstacles)
_mapObstacleLayer.InternalFeatures.Add(new Feature(obstacle.ToWellKnownText(), obstacle.ID.ToString()));
            _mapObstacleStyle._Add(ref obstacle);
When I try to remove a certain obstacle using
_mapObstacleLayer.InternalFeatures.Remove(obstacle.ID.ToString());
Nothing  happens. Before I would remove the Layer associated with the ID, but now since I only have one Layer I need to remove the obstacle from this layer. Like I stated earlier if I iterate over all the feature of the layer I do get a match for the correct ID but I don't know why it remains in the list after this call.
foreach (Feature feature in _mapObstacleLayer.InternalFeatures)
    if (feature.Id == obstacle.ID.ToString())
        Console.WriteLine("Match at " + feature.Id); // This is hit
    else
        Console.WriteLine("{0} != {1}", feature.Id, obstacle.ID.ToString());
I think I'm missing something with my transition from many-to-one Layers but I don't know what it is. Thanks!
I got an error trying to submit this and went back to checking out my code. Although the ID’s were the same between my features and obstacles it was the transition to feature that was holding me up. I was able to send in my id to remove the layer, however, the key’s for the features are very different. I solved the problem by using QueryTools to get the feature I was looking for.
Gory,
 I am glad you solve your problem by yourself. Just let us know when you have more questions.
