Determine Legend Coordinates (or any adorner layer)
I want to be sure my legends do not cover a specific layer on the map, so if they do I make some changes to extent (zoom out/shift) to be sure they are not covered.  I have a method that works if you make some assumptions on were the legend is (lower left in this case).  But I'm wondering if there is a way to get the screen or world coordinate of an adorner layer so I can make my detection code work in any case.  Not had any luck looking at the API or forums so far, below is my current code.
I'm sure I could add a switch for all possible adorner placements and then calculate its screen coordinates but wonder if there is an easier way.
        protected virtual bool LayerOverlapsLegend(FeatureLayer layer, LegendAdornmentLayer legend)
            var upperLeftLegendPoint = ExtentHelper.ToWorldCoordinate(Map.CurrentExtent, new ScreenPointF(0, Map.Height - legend.Height), Map.Width, Map.Height);
            var lowerRightLegendPoint = ExtentHelper.ToWorldCoordinate(Map.CurrentExtent, new ScreenPointF(legend.Width, Map.Height), Map.Width, Map.Height);
            var legendBBox = new RectangleShape(upperLeftLegendPoint, lowerRightLegendPoint);
            return layer.QueryTools.GetFeaturesOverlapping(legendBBox, ReturningColumnsType.NoColumns).Count > 0;
Looks like GetDrawingLocation has promise.  My only issue now is that I’m doing this outside of a drawing event and I don’t see how to get the GeoCanvas from a WinFormsMap.  I’ll keep investigating.
Brian,
 You could create a concrete GeoCanvas such as GdiPlusGeoCanvas, and draw somthing on a bitmap. If you want to draw on the map, you need to use the canvas from DrawCore method during the drawing procedures.
