Determining the internal projection parameters from a supplied XML document
 I have a client that has handed me a Shape file and other associated pieces of information.  I however cannot determine what the Internal Projection Parameters are.  Since I am new to working with this type of data I am kind of at a loss as to where I should look in the accompanying XML document to find the parameters I need.
Is there any documentation related to this topic that I can look at?  Or better yet are there tools in existence that can read the XML document and determine what my inputs should be?
Chris
Updating with new info,
 It looks like this has been exported from an Esri system if that is of any help
 Chris,
The projection info is usually stored in a .prj file. Did your client send you that? If yes, I think you need to convert the .prj file to a proj4 string and it then can be used in our system. Here is a website you can check about the projections.
spatial-reference.org/
I'm not sure about the XML you mentioned. There’s an article about defining projection with XML file for ArcIMS Map Service I found on Esri official website, please have a look and maybe that helps
esri.com/news/podcasts/t...rvices.pdf
If this article doesn't help, perhaps you can let us have a look at the XML document and we might be able to find some valuable information.
It did come with a project file.  Is there a way to load the project file into the ManagedProj4Projection object or do I need to interpret the below data into a properly formatted string?
 PROJCS["NAD_1983_UTM_Zone_18N",
GEOGCS["GCS_North_American_1983",
DATUM["D_North_American_1983",
SPHEROID["GRS_1980",6378137.0,298.257222101]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",500000.0],
PARAMETER["False_Northing",0.0],
PARAMETER["Central_Meridian",-75.0],
PARAMETER["Scale_Factor",0.9996],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
 Ended up finding the corresponding Espg code by google-ing different versions of this code.
 EPSG:26918 turns out to be NAD83 / UTM zone 18N which causes the paths to overlap perfectly with the roads on my google map satelite overview.
Chris,
 That’s great you found it.  In fact we are working on the prj, proj4 conversion now and we might have something pretty soon, then you can use our control directly to do the conversion.
That’s good to know.  Chances are most clients will have different projection settings.  It was a good experience having to find these parameters myself the first time tho.  Helped me to understand what they meant and what they were used for.
Chris,
 I am glad you have your projection issue resolved and that you learned something new. Remember, as Ben mentioned earlier, that spatial-reference.org is a very handy website to find the EPSG or ESRI code that accepts Map Suite.  And you will find various projection as you can see for your projection NAD83 / UTM zone 18N spatial-reference.org/ref/epsg/26918/. (That code can also be substituted by the Proj4 string spatial-reference.org/ref/epsg/26918/proj4/
Thank you.
