Development Build Changes (4.5.92 to 4.5.116)
I've updated my builds to the latest today (4.5.116) and now none of my street data (ShapeFileFeatureLayer) show up except for labels and railroads (they are each on their own seperate layers?  If I revert back to version 4.5.92, everything works fine.  Do you have any idea where I should start looking for whats broken (based of changes you've made from 92 to 116)?  It should be noted I'm using the code you've previously provided to stretch an overlay on zoom (as oppose to remove all tiles and show background before new tiles are loaded) in case it has to do with something there.
.Ryan.
Ryan,
I found the previously provided code for “stretch an overlay on zoom” at gis.thinkgeo.com/Support/Dis...fault.aspx
It works in both versions, however it doesn’t include the code for rendering street data, so I think you have added some code or I found the wrong code. Could you provide your code to help us found the problem and fix it?
We have done many changes between two version but I couldn’t recreate your problem.
