Different labels on each interactive line segment
I’m using your TrackInteractiveOverlay to allow the user to draw multi-segment lines or closed polygons.  But I need to be able to display the length (feet or meters) of each segment.  I can’t figure out how to place these labels using your TrackInteractiveOverlay class, which is otherwise just what we need.  Can it be used, or must I reimplement such a solution from scratch?
I’ve also looked at your RulerOverlay sample.  This has the label working pretty much exactly as I need, but I need to be able to do it for a multi-segement line and for each line segment of a polygon, preferably in real time as the user lays it out (just like RulerOverlay).
I have a hunch that the class can be made to work, but I just don’t yet have a full grasp of how to get at what I need.
Hi Rush,
We modified the RulerOverlay to fit for your case, would you please check it?
Any questions ,please let us know.
Post12357.zip (108 KB)
Wow, very nice, looks like almost exactly what I needed, and I would not have been able to get there with my current level of knowledge on the product.  Thank you.
That’s great to hear it is exact what you want! I also believe you’ll have a good understandings with map suite products as the time goes on.
 Anyway, it is our pressure to assist you. So, don’t hesitate to let us know if any queries.
As below is a update for obsoleted API.
001_Post12357.zip (76.7 KB)
Thanks, I’ll take a look and see about integrating it tomorrow.
Russ,
 Please let us know if any other questions.
