Disable markerOverlay Click event
Hello ThinkGeo People
I have two events registered in my web mapping application.
The first being MarkeroverlayclickEventArgs and MapClick event.
I want to switch between them based on some button click.
Currently, I can turn them off only after switiching off the marker layer.
Any help would be appreciated.
Vivek
Hi Vivek,
I think it’s easy for you to do on server side, because after a postback, all events will be re-registered on client side again, but a little complicated on client side using JavaScript, please check the code below:
        function handleMapClick(enable) {
            var map = Map1.GetOpenLayersMap();
            var clickHandlerControl = null;
            for (var i = 0; i < map.controls.length; i++) {
                if (map.controls.handler && map.controls.handler.CLASS_NAME == 'OpenLayers.Handler.Click') {
                    clickHandlerControl = map.controls;
                    break;
            if (clickHandlerControl) {
                if (enable) {
                    clickHandlerControl.handler.activate();
                } else {
                    clickHandlerControl.handler.deactivate();
        function handleMarkerClick(enable) {
            var markerOverlay = map.getLayer('markerOverlay id');
            for (var i = 0; i < markerOverlay.markers.length; i++) {
                if (enable) {
GetHookedClickEventMarker(markerOverlay.markers, markerOverlay)
               else{
                   markerOverlay.events.remove(etype);
Please modify the MarkerOverlay's id mentioned in the script and have a try. Any question please let us know. Regards. Johnny
Hi Johnny
Thanks for the code and sorry for delay in replying.
I was able to do it easily using server side by de-registering the event.
Vivek
Hello Vivek,
 You are welcome, please feel free to let us know your questions.
