Disable panning with right mouse
When you hold down the left or right mouse button and move the mouse over the map, the map will be panned. I want to disable the right mouse button in this regard, so that you can only pan the map while holding the left mouse button.
I have looked for this setting, but have not found it. Does it exist?
I found a different post here saying that I can write my own ExtentInteractiveOverlay and apply it as the maps ExtentOverlay - is that a good idea?
Jonas
Hi Jonas,
Yes the post you found provide the correct solution.
Please try attached sample.
8893.zip (101.1 KB)
