Disable rotating in Square Draw Mode
Is there a way to disable rotating when drawing a Square? Basically make it act like Rectangle mode does, but enforce equal sides.
I'm looking for the new shape equivalent of:
Map1.EditOverlay.EditSettings.IsRotatable = false;
Rob,
The drawing operation is hard coded in OpenLayers. But we have a work around for you which is the snap angle. Please paste the following JavaScript to the header tag in our installed sample at samples\MapShapes\DrawEditShapes.aspx.var OnMapCreating = function(map) {
     Class.Extent(ThinkGeo.prototype, {
         SetDrawMode: function(drawMode) {
             eval('var parser = parser' + this.clientId);
             if (!parser.editOverlay) {
                 parser.initDrawControls();
             var map = parser.map;
             if (drawMode == 'Normal') {
                 for (var key in parser.paintControls) {
                     if (key != 'Normal') {
                         parser.paintControls[key].deactivate();
             } else {
                     if (key == drawMode && drawMode != 'Normal') {
                         var control = map.getControl(key);
                         if (drawMode == 'Square') {
                             control.handler.setOptions({ snapAngle: 45, irregular: false });
                         control.activate();
                     else if (key != 'Normal') {
                         control.deactivate();
It snaps some specific angle and you still can draw a square which is not rotated. Please have a try and let me know how it works.
Howard
That gets close, but the initial snap is at an angle I don’t want to allow. I want it to snap at 90 degrees, but starting at 45 degrees from the positive x-axis. Any other work arounds?
 Background:
 The reason I want to limit it like this, is the user is defining an area to export to a same width and height image file.
Rob,
I see, I changed my code; in this way, you can use draw rectangle mode to draw the square you want. Please replace the JavaScript below.
    OpenLayers.Handler.RegularPolygon = OpenLayers.Class(OpenLayers.Handler.RegularPolygon, {
        move: function(evt) {
            var maploc = this.map.getLonLatFromPixel(evt.xy);
            var point = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
            if (this.irregular) {
                var ry = Math.sqrt(2) * Math.abs(point.y - this.origin.y) / 2;
                this.radius = Math.max(this.map.getResolution() / 2, ry);
            } else if (this.fixedRadius) {
                this.origin = point;
            } else {
                this.calculateAngle(point, evt);
                           point.distanceTo(this.origin));
            this.modifyGeometry();
                var dx = point.x - this.origin.x;
                var dy = point.y - this.origin.y;
                var ratio;
                if (dy == 0) {
                    ratio = dx / (this.radius * Math.sqrt(2));
                } else {
                    ratio = dx / dy;
                this.feature.geometry.resize(1, this.origin, ratio);
                this.feature.geometry.move(dx / 2, dy / 2);
            if (this.sides == 4 && this.irregular) {
                var bounds = this.feature.geometry.getBounds();
                var width = bounds.getWidth();
                bounds.right = bounds.left + width;
                bounds.bottom = bounds.top - width;
                this.feature = new OpenLayers.Feature.Vector(bounds.toGeometry());
                this.clear();
            this.layer.drawFeature(this.feature, this.style);
Howard
Perfect! Thanks for hacking up OpenLayers for me.
Rob,
 You are welcome. We just want to do our best to provide you good services.
 Howard
