Thank you for the post you can certainly achieve your requirements with Map Suite.
To accomplish your requirements you will need to join your custom data from the SQL Server database to a layer of the map at runtime. In your case the layer on the map that you will want to join to will be the Country02.shp file, this shapefile contains all the country boundaries of the world.
From a coding perspective it will be pretty straightrforward to wire up, Map Suite provides an Event on the FeatureSource called CustomColumFetch that you can implement that raises an event for each feature inside the layer (In your case each feature will be each an individual country). This allows you to see what country it is and add your custom data to that feature. Once the feature has your custom data it's just like any other data in the layer and you can labeling or rendering based off of it's value.
Luckily we have a How Do I sample that shows how to use this event and to load in custom data. The sample has all the source code to help get you started. You can check out this code by loading the samples that were installed with the evaluation edition or by going to websamples.thinkgeo.com.
The sample you will want to look at is under the Feature Layers section and it's called "Using Custom Data".
Please let us know if you have any questions, we are here to help.
Thanks Batman's detail information, I also has some additional information might give you some help.
According to your description, I suggest you refer to sample "Highlight a Feature While Hovering" and "Load a MSSQL2008FeatureLayer" in our “HowDoISamples”. I think you can do some research on “HowDoISamples”. Then you will archive your requirement easily.
Hey i figured it out …Thanks again…batman can you suggest any tutorial for me, from where i can get the basic understanding of implementing maps in asp.net
Can you tell me how to obtain country name. Because i only thing that I can fetch is the country id, is there a table in which country id and name is written?
How to obtain country name? Sorry, I didn’t get your intent. Could you please give us a detailed explanation? Such as, What’s the data source? What do you get country name for? So we can help you better.
How are you doing?...I guess quite busy in replying to questions...:-) ...anyways I wanted to ask that the event you told me i.e. FeatureSource_CustomColumnFetch gives you info reagrding the country id and not the country name (e.ID) ...However I wanted to know the country name as well...But dont bother....i figured it out.....now my question is can i set the background color of any country using this FeatureSource_CustomColumnFetch event based on some condition?
Let say we have certain countries in the sql table:-
Country Revenue (in million dollars)
US 10
India 20
China 0
Japan 10
and we want to display all the countries with revenue greater than 10. So the question is how to set the background color of these countries so that they can be displayed accordingly.
I did go through your sql querry example however it does not full fill the criteria as i guess it is only showed to apply sql query on pre defined columns that are present in the worldlayer.
I guess it would not consume much of your time....:-)
Your requirement is not complicated. Firstly, you can use sql query to get all the name of countries that satisfy the condition. Then you can use ValueStyle to display the countries accordingly.
The specific usage of ValueStyle is in the “Styles” - “Get a group of color in the same quality family” of “HowDoISamples”. Reading more samples will help you finish your web application better.
Below is a link to our online store where you can see all the pricing. I also included a link to the ‘contact us’ page so you can get in touch with a sales representative that can help you.
Thank you so much James, it worked However can you suggested something so that whole world map apppears on the entire page width or boundries....i think we would have to adjust zoom level....Wanted your confirmation.
Thanks and enjoy in between your work by taking deserving breaks
You probably need to calculate by yourself to get a suitable extent fit the entire page, for example, you want to show whole world map that the extent is (-180,90,180,-90) and map's size is 1075*562 in pixel, the sample code is below:
