Display MrSid Image in V7.0.0.0
MapSuite Team,
I upgraded to V7.0.0.0 and see two issues with MrSid raster layers.
The first is that the displayed extent of the MrSid Layer does not match the displayed extent of the other ShapeFileFeature Layers.  The MrSid Layer is offset slightly by maybe 300 feet.
The second is that tiles are not being created for the MrSid Layer.  Since the MrSid was offset slightly from the other layers I decided to delete all the existing MrSid tiles thinking they needed to be recreated.  But when a png is manually opened using Microsoft Preview there is nothing there when there should have been an image tile.
Has this been corrected in V7.0.8.0?
This had all worked under V6.0.134.0.
Dennis
Hi Dennis,
Thanks for your post and sorry for the inconvenience, we have tried to recreate the problem, but it didn’t show up with our own data, following is a result picture of our test:
Would you please upload your data or send it to forumsupport@thinkgeo.com(if it is confidential or surpass the upload size limitaion) for a further test?
Waiting for your further information
Summer
Summer,
I have found that I did not have Visibility set on my MrSid’s which caused the tiled png to contain ‘null’ images.  Once Visibility was set V7 properly creates and displays the tiled png images.
It still does not display the V6 tiled png’s properly, but at this point I am not concerned about that since I will simply recreate the tiles under V7.
Sorry to have troubled you about this.
Dennis
Hi Dennis,
 Thanks for your sharing and hope "recreating tiles" will be helpful.if you have any more question , please feel free to let us know.
 Best Regards
 Summer
