I am trying to display Bing map using ThinkGeo Android Suite. But I am getting this error:
System.ArgumentOutOfRangeException: The input double value is out of range.
Parameter name: screenWidth
Here is the code:
01.public class ThinkGeoActivity : Activity02.{03.private MapView androidMap;04.protected override void OnCreate(Bundle bundle)05.{06.PclShareEnvironment.Current = new AndroidEditionPclShareEnviroment();07.08.base.OnCreate(bundle);09.SetContentView(Resource.Layout.DisplayASimpleMap);10.androidMap = FindViewById<MapView>(Agtrix.Droid.Resource.Id.androidmap);11.12.PointShape thinkGeoCoordinate = new PointShape(153.5084, -28.5537);13.RectangleShape defaultExtent = new RectangleShape(151.209389, -33.430000, 151.219389, -34.29000);14.15.ManagedProj4Projection wgs84ToBingProjection = new ManagedProj4Projection();16.wgs84ToBingProjection.InternalProjectionParametersString = ManagedProj4Projection.GetWgs84ParametersString();17.wgs84ToBingProjection.ExternalProjectionParametersString = ManagedProj4Projection.GetBingMapParametersString();18.wgs84ToBingProjection.Open();19.thinkGeoCoordinate = (PointShape)wgs84ToBingProjection.ConvertToExternalProjection(thinkGeoCoordinate);20.defaultExtent = wgs84ToBingProjection.ConvertToExternalProjection(defaultExtent);21.wgs84ToBingProjection.Close();22.23.Marker thinkGeoLocation = new Marker(this);24.thinkGeoLocation.Position = thinkGeoCoordinate;25.thinkGeoLocation.OffsetX = -22;26.thinkGeoLocation.SetImageResource(Resource.Drawable.Point);27.MarkerOverlay markerOverlay = new MarkerOverlay();28.markerOverlay.Markers.Add(thinkGeoLocation);29.androidMap.Overlays.Add("markerOverlay", markerOverlay);30.31.BingMapsTileOverlay bingMapOverlay = new BingMapsTileOverlay("Bing Key Here");32.androidMap.Overlays.Add(bingMapOverlay);33.34.35.bingMapOverlay.MapType = BingMapsMapType.AerialWithLabels;36.androidMap.CurrentExtent = defaultExtent;37.androidMap.Refresh();38.androidMap.ZoomTo(thinkGeoCoordinate.Buffer(500, GeographyUnit.Meter, DistanceUnit.Meter).GetBoundingBox());39.40.41.}42.43.44.45.46.}
Can you correct any issues with the above code? Or send me a sample solution. Note that the similar code was successfully used on iOS.
