Displaying Graticules in PSG projection in V9.0
Dear All,
             Now that we are able to set Lat_0=90 in Polar Stereographic(PSG) Projection, problem faced is in displaying graticules as desired.
Display of graticules is not consistent when zooming in or out or panning. Request advice and modifications ( if required) to address the following points
1. Display of graticules is not in desired intervals. It should be possible to display Graticules in multiple of 1,5,10 degrees
2. Provide for setting Graticules interval for different zoom level.
3.Is there a provision for property settings of Graticule Layer? If not, can it be provided.
Best wishes,
Riyaz
Hi Riyaz,
 You can see our graticules are dynamic generated when you zoom in/out, which can make the lines looks good when each extent.
 If you need to get a group static graticules which based on degrees, I think you can implement a custom GraticuleAdornmentLayer, and draw the lines in the DrawCore function.
Hi Don,
Thanks for your reply. it’s helpful for me.
Best wishes,
Riyaz
Hi Don,
 Best wishes,
 Riyaz
Riyaz,
 Please feel free to let us know if any other questions.
