Displaying KML files
Hi all,
I've come into possesion of a few .kml files that I would like to display on my map.  Currently, I'm using all .shp files, so I've never had the please of working with this type of file before.  I can't seem to locate any info on using these files, either.  Might someone give me a brief rundown on if and how I can use these files?  Thank you
-Dustin
Dustin,
We don’t intrinsically support KML but if you understand KML pretty well, you can add the support yourself very easily. Here attached is a sample which supports the simplest KML (with one point), please have a look.
Also, here is a post about exporting from shape file to KML, have a look if you are interested.
805-KMLLayer.zip (101 KB)
Thanks very much for the response Ben.  I did find the KML spec, and while it does seem to be doable, seems very time consuming for something that won’t be used very often by us.  As such, I found an online converter that changes KML to SHP files at:  zonums.com/online/kml2shp.php
 Thanks again!
 -Dustin
Dustin,
 That might be best if it won’t be used very often.  Thanks for sharing that link!
