Distance Between Lines Incorrect
Please see attached console app.  The function GetDistanceTo when used on lines used to return the closest distance between the two lines.  Now, it returns something entirely different.  In my app, I try line to line, point to point and line to point calculations.  Point to point is the only one that is working right.
This has cropped up somewhere between versions 7.0.0.45 and 7.0.0.117.
It’s a big deal for me as I’ve a lot of operation using this type of evaluation.  And, I got a fix in version 117 which I can’t apply because of this problem.
Damian
DistanceBetweenLines.zip (18.6 KB)
Hi Damian,
 Thanks for your informative and detailed instruction on this, it’s caused by a change done during the days you mentioned, thank you so much. Now it has been fixed, please get the latest build 7.0.0.144 or higher to have a try.
Hi Johnny,
 Can you please check on the customer portal?  The daily builds seem to be stuck again.  Last shown production version is 7.0.0.142.
 Damian
 There is a mistake on our daily build server and now it should be ok.
 Would you please try again?
Johnny,
 The version on the site is now 7.0.0.149.  When I try this version, it does indeed fix this problem; however, it makes the fix applied to my last post regarding "GetFeaturesWithinDistanceOf" no longer work.
 The two issues must be tied somehow or the changes that were made from my last post were omitted in this build.
 Please check into this.
 Damian
Hi Damian,
 You are right. The two issues are tied and now both of them are fixed. would you please get the latest version(7.0.0.154 or 7.0.154.0 might be still building, please waiting for several hours)
 Sorry for any inconvenience.
There are no updates on the customer portal past 7.0.0.151
Hi Damian,
 We are sorry our daily build system is updating and we have to upload the new dll packages manually. Would you please wait for another days until the 7.0.0.154 or higher available in custom portal?
 Sorry for the inconvenience.
I’ve been waiting several days now and the customer portal is still stuck on 7.0.0.151.
 Damian
Hi Damian,
 We are so sorry for the long time waiting. Now, the 7.0.162.0 and 7.0.0.162 are available in the customer portal, please check it.
Thank you Johnny.  I can confirm that both functions are working as expected.
 Damian
Hi Damian,
 Good to hear both of them work.
