DistanceAlongCurve
Dear support,
I am an ESRI client for now and I'm testing MapSuite 3.0.
I need to know if there are a easy way to measure a distance along a polilyne.
So I have a Feature that is a polilyne and I have a couple of points in that Polilyne.
This is how I got the Points:
MultipointShape
 overlapPointShape = currentMultilineShape.GetCrossing(areaBaseShape);
How can I find the distance between each of my points and the begining of the Polilyne (in Meters).
André
This is one possible solution:
Get the point representing the beginning of your line by calling lineShape.GetPointOnALine(StartingPoint.FirstPoint, 0).
Then just get the distance by calling GetDistanceTo on the starting point and passing in your point.
PointShape startingPoint = lineShape.GetPointOnALine(StartingPoint.FirstPoint, 0);
double distance = startingPoint.GetDistanceTo(crossPoint, map.MapUnit, DistanceUnit.Meter);
Miguel,
Thanks for your post and interests in MapSuite component, welcome you to ThinkGeo Mapsuite Destkop discussion forum.
Also, Thanks for your sharing , Chad. I am a little disagree with your solution because requirement from Miguel is getting the distance along a polyline instead of getting the distance between two points directly.
Following is some code snippet of my opnion, maybe not correct either:).
LineShape targetLineShape;
LineShape tempLine = targetLineShape.GetLineOnALine(StartingPoint.FirstPoint, crossPoint);
double crossPointDistance = tempLine.GetLength(GeographyUnit.DecimalDegree, DistanceUnit.Meter);
If you have any more good suggestions just feel free to let it out.
It work Fine
 Thanks Yale and Chad
 Miguel
Miguel,
 Thanks for letting me know your status.
