Dlls version 6.0.360.0 does not redraw on pan with SingleTile mode
    WpfMap.Pan() does not redraw on pan (from code) when configured in SingleTile mode. It does when pan by using the mouse or other mouse movements.
   Here is the simple demo: dl.dropboxusercontent.com/u/6792052/ScreenFlow.mov
Hi Carlos,
 Thanks for your video, it shows your question very clear.
 It’s proved to be a bug and we have fixed it in the latest version. Please get the latest version (6.0.362.0) to try it out.
 Note: the latest package is still building, please waiting for couple hours.
 if any other questions, please feel free to let us know.
 Hope it helps
Hi Johnny,
 Thanks a lot for fixing it so quickly!
 Carlos
Johnny,
  Build version seems to be wrong, It says WpfDesktopEditionFull6.0.353.0DllPackage.zip
Hi Carlos,
 Thanks for your input, but I am sorry to say that I didn’t understand “Build version seems to be wrong, It says WpfDesktopEditionFull6.0.353.0DllPackage.zip”, would you please tell us if you have any problem in getting version 6.0.362.0 or later? it can be avaiable at helpdesk.thinkgeo.com
 Waiting for your reply
Hi Johnny
  I was a "glitch" in your automated build system. On friday morning the dlls at customer portal were 6.0.360.0, and in the afternoon it went back to 6.0.353.0 ,I even downloaded it to check if it was only an error in the zip package name, but they were old DLLs indeed. Today It was OK and I downloaded 6.0.364.0 dlls
 Carlos
i Biju,
 Thanks for the further information. When using WorldMapKitWmsDesktopOverlay the right MapUnit should be DecimalDegree rather than Meter.
 Thanks for reporting the feature that “scale not changing under Meter along the latitude”, I guess this should be a new feature for us, currently, the scaleLine doesn’t use a geodesic measurement, can you let us know if it’s very urgent for you now, because, our major release 7.0 is upcoming soon, we are unable to do a big changes to it now, ideally we can add a new property, maybe called “geodesic”, to scaleLine, so that we can do the switch.
 About the last issue,  we will calculate the scale with parameter of latitude, and the latitude we choose is the one on the center line of screen, but in the attached picture situation, the center of map doesn’t have a latitude on it, so the scale can’t be calculated and therefore will not be displayed.
i Biju,
Hi Carlos,
 Glad to hear that you get 6.0.364.0, I hope it will be helpful for you. About “On friday morning the dlls at customer portal were 6.0.360.0, and in the afternoon it went back to 6.0.353.0”, thanks for telling us this weird phenomenon, we are doing the investigation on it now.
 Best Regards
