I was curious if the latest ThinkGeo 4 Desktop Edition supports connections to SQL Azure. I suspect that it would connect as if it were a SQL Server 2008 database, but just wanted to confirm and see if anyone had tested this capability. Any insight would be greatly appreciated.
I did not have the chance to try out the SQL Azure yet, while I think it should be compatible with the current SQL server 2008 because the background of the SQL Azure is still SQL server platform. I think if we use the Sql2008FeatureLayer and passed in those connection parameters, if we can connect it by calling Open, then everything should works fine.
