DragMode in other than SimpleMarkerOverlay
Is there a way to set DragMode in other overlays than SimpleMarkerOverlay.
I am loading huge amount of markers and use InMemoryMarkerOverlay in all other pages.
On this page I need to let user drag the marker to let them correct the location.  What is the best way to do it?
Hello Jakub,
Here is a sample on how to drag markers in InMemoryMarkerOverlay; just replace the AddAnInMemoryMarkerOverlay file in our how do I sample. Please have a try and let me know if you have more queries.
002_001_AddAnInMemoryMarkerOverlay.txt (5.8 KB)
Thanks. This seems to be Desktop code.
 Does it work the same in the Web edition?
Hello Jakub,
 Sorry I have made a wrong product, please give me some time I can write a web sample.
 Thanks for your patience.
If you are writting a sample I will need to retrieve the Latitude, Longitude and the Marker ID (ColumnValue or Tag) at the Drag End.
 Basically I need to let user edit the location of the marker and save it back to database.
Hello Jakub,
 Thanks for your further information, about this sample, we can’t make it working in server side, so I need more time to do it in the client side. I will post here as soon as possible.
I appreciate your help.
 If the client side can collect the Lat, Long and Marker ID and post it into text boxes then there can be a server side routine to update the database.
Any update oin this?
Hello Jakub,
 Sorry I still working on this, I will post here as soon as I finished it.
 Thank you for your patience.
Has this been completed for the Web version?  Thanks
Hello Chad,
 Sorry I’m still working on this, I will post here as soon as I finished it.
 Also you can follow the way I talked above, use the client side script to handle the drag event to did this.
Any update on this?
Hello Jakub,
 Sorry I’m really busy these days, could you please create a ticket for this, then I can focus on it.
 Thanks for your patience and sorry for waiting.
done. created a ticket.
If you could please post the solution to this thread when found I would appreciate it.
Hello Jakub,
 Thanks for your ticket, I will working on that.
