Dear ThinkGeo Team,
We have a requirement of drawing shapes having one or multiple Arc(s), that means for example while drawing a Polygon I can add an Arc and then continue drawing the polygon shape, could be drawing one Arc or multiple as per the need.
I am not sure if you guys having an API which can make my life easy or what sort of ideas you can throw to me so I can use to start doing that requirement.
As per the shape of the hyperlink, it is a sector simple form of polygon with and Arc, I need to be able to “click 1” create the origin or centre point and then drag the mouse up and then make “Click 2” that is going to be my “Radius” and then drag/move the mouse clock wise and then “Click 3” difference between “Point 1” and “Point 2” is going to give me the angle which allow me to create the Arc.
Your help is much appreciated
Thank You,
Ossama
