Hi ThinkGeo,
Drawing Label on Marker increase the image size even if the label is completely drawn inside the Image (see attached image sizes in zip files)
Anil
VehicleImageAfterLabel.zip (3.98 KB)
OnLabelDrawImg.zip (3.35 KB)
Hi ThinkGeo,
Anil
Anil,
Thanks for your post!
I checked your attached images I think that’s a bug for the web edition, I have posted it to our development team if there are any updates I will let you know,
Scott,
Hi Scott,
Is there timeline when we we can have the fix?
Anil
Anil,
Thanks for your patience.
I have contacted our product team, they are working on this issue, please subscribe this post and I will reply the result as soon as they finish it.
Anil,
Sorry after our product team research, we can’t reproduce this problem. We have a method “OutputIcon” in ImageResource which is related to webimage, from the logic there is no place to increase the image size.
So could you please provide a sample that we can recreate the problem?
Hi Gary,
I attach sample code files from "Label and Rotate a Marker" example to illustrate the issue. Copy Vehicle1.png to them/default/samplepic folder.
On Checking button "Show Text", icon looks small but its actual size is much large with lot of dead white space .
Anil
LabelAndRotateAMarkerFilesAndPng.zip (4.51 KB)
Anil,
Thanks for the sample, I have tested it, and please see the attach image, is this the dead white space you mentioned?
Hi Gary,
I attach the snapshots of the Marker I see on test sample. Use Sample I sent to display label inside the marker instead of outside.
In the attached zip file you will see three snapshots.
BeforeSetting Label -- Normal visibility
AfterLabel - Labels shows inside the marker but it is much diminished.
OnSavingExploreImage - Save the image from browser into your folder. See in explorers with Large icons setting. You will dead space around icon.
Anil
LabelOnMarkerImageIssue.zip (177 KB)
Anil,
Thanks for remind, this time I saved the image and got the same result as yours.
I will reported to our product team and tell you the reason.
Anil,
Thanks for your patience, our product team have fixed this issue, you can get the latest daily build (5.0.67.0 or later) to have another try.
Any more questions please feel free to let me know.
Hi Gary,
I tried using 5.0.67 and still problems exist (see attached images)
1) Marker retains visibility size but actually also increases in byte size.
2) On saving you can see dead space around icon.
Anil
LabelOnMarkerImages.zip (7.66 KB)
Anil,
I’m sorry to get you in trouble, I will connect our product team and make sure what’s wrong.
I will let you know as soon as possible.
