Drawing Lines using InMemoryFeatureLayer very slow
I am drawing up to 500 lines at a maximum rate of 20 lines per second. I found that the map display is getting slower when the updates is that fast.
Any suggestions on how to solve this performance issue ?
Attaced is my code.
Public Sub Draw_Line(ByVal Ref, ByVal LongBeg, ByVal LatBeg, ByVal LongEnd, ByVal LatEnd, ByVal Layer, ByVal Label, ByVal Colour, ByVal LineType, ByVal Linewidth)
        Dim sysColour As System.Drawing.Color = System.Drawing.ColorTranslator.FromOle(Colour)
        Dim geoColour As GeoColor = GeoColor.FromArgb(sysColour.A, sysColour.R, sysColour.G, sysColour.B)
        Dim valueStyle As New ValueStyle()
        valueStyle.ColumnName = "Line"
        Dim valueItem As New ValueItem()
        valueItem.DefaultAreaStyle.OutlinePen.Color = geoColour
        valueItem.DefaultLineStyle.OuterPen.Color = geoColour
        valueItem.DefaultLineStyle.OuterPen.Width = Linewidth
        valueItem.Value = CStr(Ref)
        valueStyle.ValueItems.Add(valueItem)
        Dim inMemoryLayer As InMemoryFeatureLayer = CType(WinformsMap1.FindFeatureLayer(Get_Layer(Layer)), InMemoryFeatureLayer)
        inMemoryLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(valueStyle)
        inMemoryLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        inMemoryLayer.Open()
        inMemoryLayer.Columns.Add(New FeatureSourceColumn("Line"))
        inMemoryLayer.Close()
        Dim lineShape As New LineShape()
        lineShape.Vertices.Add(New Vertex(LongBeg, LatBeg))
        lineShape.Vertices.Add(New Vertex(LongEnd, LatEnd))
        lineShape.Id = CStr(Ref)
        Dim newFeature As Feature = New Feature(lineShape)
        newFeature.ColumnValues.Add("Line", CStr(Ref))
        inMemoryLayer.InternalFeatures.Add(newFeature)
        WinformsMap1.Refresh(WinformsMap1.Overlays())
    End Sub
Dana,
   By looking at your code, I think that the inefficiency might come from the fact that you are refreshing the map each time you are calling the function Draw_Line. If you are calling that function 20 times in a second and you are refreshing the map each time, this is going to cause a performance issue. It would make more sense to call WinformsMap1.Refresh() only one time, once you have added all the new features to your inMemorFeatureLayer. I hope this tip is going to help.
Hi Val,
 Thanks for the feedback. I agree with your observation.  The implementation of an external refresh timer to "bulk" refresh newly drawn lines should work.  I kind of hoped that there is an "auto-refresh" mechanism for such scenarios.
 Dana
Dana,
 I am glad I could point you to the right direction. We don't have an "auto-refresh" mechanism because we can never assume at what point some changes should be reflected on the map. Thank you.
