Drawing straight lines at an angle
 I am attempting to get a straight line to look smooth on my map when drawn at an angle.  I have attached a screen capture to help explain.
The picture has several examples.  All the lines below are straight lines from a point A to point B.  The only changes are the angle they are drawn.  I can't seem to find the setting that will make these appear smooth (smoothingmode or something like that?).  I am using line width of 1, do I need a wider line to get that smoothing effect?  Where should I look to set that value?  I don't see a property at the map level that would change the drawing quality.
 Jake,
Thanks for the question!
You can set the drawing quality off of your feature layer using the DrawingQuality property.  If you need more advanced controls you can also modify some properties directly on the GeoCanvas.   Check out the link below for more explanation.
wiki.thinkgeo.com/wiki/Think...ingQuality
However keep in mind if your line is very thin there is only so much that can be done so you may thicken your line a little to get the desired effect.
Hope this helps, Thanks!
