DrawingQuality.HighSpeed
Setting DrwingQuality to HighSpeed cause drawing problem as attached picture
 ShapeFileFeatureLayer shpFeatureLayer = new ShapeFileFeatureLayer(MapGlobals.mapFiles.mapFileName);              shpFeatureLayer.RequireIndex = true;
shpFeatureLayer.DrawingMarginPercentage = 50;
shpFeatureLayer.DrawingQuality = DrawingQuality.HighSpeed;
I looked at the screen shot you attached. This is something I have never seen before and this is something I could not reproduce with a sample using the same properties you have. There might be a problem with the server or client cache. The first thing I would do is to clear the different cache you have and see if that helps. If you still have the problem, I would ask you send us a little sample app from you. Thank you.
