Dynamcally changing Map Extent
     How do i dynamically change map extent? The issue I have goes like this: initially there is a world map(a baseLayer) that is loaded and like wise the map extent is set to the bounding box of that map. Now there is a time when the user clicks a button , and so a new map(say US states) has to be loaded with the extent to be set according to the new map's bounding box. What's happening is that even though I reassign the map extent to the new bounds, it is not changing.  Am i missing something here totally or just a small fix is all that is required?
Hi, ben, I have tested it using the new version of WebEdition; it works well. As far as I know, if user register a post back click event on button, you could add layer or change the property of map what you want. So, here I provide a simple sample for you. If you still have problem, please check out the latest DLL package from helpdesk.thinkgeo.com.
Khalil
1956-DisplayASimpleMap.zip (1.99 KB)
