Edit overlay - enable rotate for subset of features in the layer
Hallo
I have a scenario in which the user can start editing features
from an “InMemoryFeatureLayer”. When the edit starts I move the all features of
the layer to the EditOverlay.
My problem is that subset of the features should be only rotatable
and movable.
I understand that I can control in the edit type by setting
the following properties of the EditOverlay, but this affect all the features
in the EditOverlay
ThinkGeoMap.EditOverlay.CanResize
= false;
ThinkGeoMap.EditOverlay.CanRotate
= true;
ThinkGeoMap.EditOverlay.CanReshape
= false;
ThinkGeoMap.EditOverlay.CanRemoveVertex
= false;
ThinkGeoMap.EditOverlay.CanAddVertex
= false;
ThinkGeoMap.EditOverlay.CanDrag
= true;
How can I have this unique edit (CanDrag= true + CanRotate=true) only for
specific features in the Edit overlay while keeping other features editable as
default (all edit properties are enabled)
I tried to
use EditInteractiveOverlay but it did not helped.
Can I have
more than one editOverlay in same way?
Do you
have any other suggestion regarding this issue?
Thank you
Miri
Hi Miri,
 I tested multiply EditOverlay, it won’t works.
 So the solution should be create your custom edit overlay like this:
  public class MyEditEditInteractiveOverlay : EditInteractiveOverlay
        protected override System.Collections.Generic.IEnumerable<Feature> CalculateResizeControlPointsCore(Feature feature)
            System.Collections.Generic.IEnumerable<Feature> features = new System.Collections.ObjectModel.Collection<Feature>();
            if (feature is your special feature)
                return features;
            else
                return base.CalculateResizeControlPointsCore(feature);
        protected override System.Collections.Generic.IEnumerable<Feature> CalculateVertexControlPointsCore(Feature feature)
                return features;
            else
                return base.CalculateVertexControlPointsCore(feature);
thank you, it is working good
Hi Miri,
 I am glad to hear that works for you.
