Editing a PersonalGeoDatabaseFeatureLayer
I'm trying to edit a personal geodatabase (ESRI) using the PersonalGeoDatabaseFeatureLayer. The layer renders great and I'm able to edit a column value but I'm not able to persist those changes. Following an example on how to edit a shapefile's attributes I attempted the following:
LayerOverlay overlay = new LayerOverlay();
MapControl.Overlays.Add(overlay);
PersonalGeoDatabaseFeatureLayer geoLayer = new PersonalGeoDatabaseFeatureLayer(@"C:\Users\matt.conrad\Desktop\CheckOut_Output.mdb", "Id;
geoLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.City7;
geoLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
overlay.Layers.Add(geoLayer);
geoLayer.FeatureSource.Open();
var structures = geoLayer.FeatureSource.GetAllFeatures(new List<string>() { "Id", "BirthYear" });
// edit a feature's attribute
Feature sample = structures.SingleOrDefault(st => st.Id == "{cfcbcd6e-363c-41bb-8a94-caa29d09e9cd}");
sample.ColumnValues["BirthYear"] = "1904";
// exception thrown here (the EditTools object is NULL)
geoLayer.EditTools.BeginTransaction();
// I tried this instead of the line above and a differenct exception is thrown ("the FeatureSource is not editable")
geoLayer.FeatureSource.BeginTransaction();
geoLayer.EditTools.Update(sample);
geoLayer.EditTools.CommitTransaction();
geoLayer.FeatureSource.Close();
Any suggestions on how I can persist these changes? I would also like to be able to edit the geography as well but I thought I'd start here.
Surprisingly I haven't found any similar questions in the forums. I thought more people might be trying this.
Matt
Matt,
 The exception is thrown by base class FeatureSource, that means PersonalGeoDatabaseFeatureSource doesn’t override the CommitTransactionCore method to
 Implement edit function, but if you have logic to do it, you can create a custom PersonalGeoDatabaseFeatureSource, and implement by yourself.
 Sorry for inconvenience.
