EditOverLay and Internet Explorer 8
With Internet Explorer 8, when using EditOverylay, I am getting a scripting error or 'Invalid argument.' failing on line:
style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");
To reproduce the problem, I run the VS2008 HowDoISamples, TrackShapeFinishedEvent.aspx and click any of the draw shape buttons (i.e. Draw Polygon).
Thanks and let me know if this is a problem with the product or a setting that I can change.
Tony,
 It’s a known issue in IE8 which doesn’t support VML in this way; it has been fixed in our latest version. We’ll release it when it’s stable. On the other hand, you can view your application as compatible mode in IE8 which also works fine.
 If you want to use our temporary version which is not full tested, please contact our support for it.
 Thanks for reporting.
 Howard
