EditOverlay issues
I am using a custom edit overlay to control the shape of the multipolygons in the overlay when the user resizes it.  I have three issues and I'm not sure if they are related to the custom overlay or EditOverlay in general.
1) When I have a feature in the edit overlay and I pan the map by dragging it, the labels that I put on the control points disappear.  They don't reappear until a refresh is done.
2) My users complained about the size of the control points being too small and that they sometimes panned the map instead of drug the control points.  I tried to resolve this by increasing the symbol size of ValueStyle)customEditOverlay.ExistingControlPointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles [0] ).ValueItems [0].DefaultPointStyle;
but the symptom still remains.  Sometimes it is very difficult to grab the control points even if the mouse appears to be on one...is there a way to increase the 'hot spot' for the control points?
3) When there is no feature in the EditOverlay, if I click to drag the map in a spot where the control points WOULD be if the feature was in the EditOverlay, the map pans but it doesn't stop panning...it follows my mouse after I stop the drag attempt.  This continues until I click and drag again at which point it stops once I complete my drag.
Here is my custom edit overlay:
/// <summary></summary>/// Define our custom edit overlay for modifying approach maps /// [ComVisible(false)] public class ApproachInteractiveEditOverlay : EditInteractiveOverlay { // // Point reference for PolygonShapes (Channel Segments) // // // | target CP | // ---0----------------------------------------------0---------0--- // | | // | V0 side1 |V1 // O---------------------------O----------------------------O // f | CP | b // r | | a // o | | c // n | | k // t | | // | V3 CP |V2 // O---------------------------O----------------------------O // | side2 | // | | // #region Events public event EventHandler ApproachChanged; #endregion Events #region Properties public ResizeMode ResizeMode { get { return m_resizeMode; } set { m_resizeMode = value; } } private ResizeMode m_resizeMode; public RotationProjection Projection { get { return m_projection; } set { m_projection = value; } } private RotationProjection m_projection = new RotationProjection(); #endregion Properties #region Constructors public ApproachInteractiveEditOverlay() { } #endregion Constructors #region overrides /// <summary></summary>/// Kludge to prevent MapSuite from adding vertex when editing /// ///
<param name="targetFeature" />///
<param name="targetPointShape" />///
<param name="searchingTolerance" />/// <returns>protected override Feature AddVertexCore( Feature targetFeature, PointShape targetPointShape, double searchingTolerance ) { return new Feature(); } /// <summary></summary>/// Calculate control points of feature. /// ///
<param name="feature" />Feature needing control points /// <returns>Collection of control point featues (PointShape) protected override IEnumerable<feature> CalculateVertexControlPointsCore( Feature feature ) { if ( feature.GetShape() is MultipolygonShape ) { return GetVertexControlPoints(feature); } return base.CalculateVertexControlPointsCore(feature); } /// <summary></summary>/// Create Vertex Control Points for editing approach /// ///
<param name="feature" />/// <returns>protected Collection<feature> GetVertexControlPoints( Feature feature ) { Collection<feature> controlPoints = new Collection<feature>(); if ( feature.GetShape() is MultipolygonShape ) { MultipolygonShape shape = feature.GetShape() as MultipolygonShape; Collection<vertex> lineEnds = new Collection<vertex>(); int idx = 0; foreach ( PolygonShape ps in shape.Polygons ) { lineEnds.Clear(); lineEnds.Add(ps.OuterRing.Vertices [0]); lineEnds.Add(ps.OuterRing.Vertices [3]); Feature frontPoint = new Feature(new LineShape(lineEnds).GetCenterPoint()); frontPoint.ColumnValues.Add("PointId", idx.ToString()); frontPoint.ColumnValues.Add("Label", "[" + (idx + 1).ToString() + "]" ); controlPoints.Add(frontPoint); idx++; } if ( shape.Polygons.Count > 0 ) { PolygonShape last = shape.Polygons [shape.Polygons.Count - 1]; lineEnds.Clear(); lineEnds.Add(last.OuterRing.Vertices [1]); lineEnds.Add(last.OuterRing.Vertices [2]); Feature tailPoint = new Feature(new LineShape(lineEnds).GetCenterPoint()); tailPoint.ColumnValues.Add("PointId", "Tail"); tailPoint.ColumnValues.Add("Label", "[" + (idx + 1).ToString() + "]"); controlPoints.Add(tailPoint); } if ( feature.ColumnValues.ContainsKey("PolygonIndex") ) { idx = Convert.ToInt32(feature.ColumnValues ["PolygonIndex"]); if ( idx < shape.Polygons.Count ) { PolygonShape ps = shape.Polygons [idx]; lineEnds.Clear(); lineEnds.Add(ps.OuterRing.Vertices [0]); lineEnds.Add(ps.OuterRing.Vertices [1]); Feature side1Point = new Feature(new LineShape(lineEnds).GetCenterPoint()) ; side1Point.ColumnValues.Add("PointId", "Side1"); side1Point.ColumnValues.Add("Label", ""); controlPoints.Add(side1Point); lineEnds.Clear(); lineEnds.Add(ps.OuterRing.Vertices [3]); lineEnds.Add(ps.OuterRing.Vertices [2]); Feature side2Point = new Feature(new LineShape(lineEnds).GetCenterPoint()); side2Point.ColumnValues.Add("PointId", "Side2"); side2Point.ColumnValues.Add("Label", ""); controlPoints.Add(side2Point); } } } return controlPoints; } /// <summary></summary>/// Handle reshaping of approach maps. User is dragging a control point. /// ///
<param name="sourceFeature" />feature being reshaped ///
<param name="sourceControlPoint" />control point used to reshape ///
<param name="targetControlPoint" />destination point /// <returns>protected override Feature MoveVertexCore( Feature sourceFeature, PointShape sourceControlPoint, PointShape targetControlPoint ) { Feature returnFeature; try { sourceControlPoint = (PointShape)Projection.ConvertToInternalProjection(sourceControlPoint); targetControlPoint = (PointShape)Projection.ConvertToInternalProjection(targetControlPoint); // // Kludge to find out which source control point is being used // Feature sourceCPFeature = SelectControlPointFeature; string ptId = string.Empty; if ( sourceCPFeature.ColumnValues.ContainsKey("PointId") ) { ptId = sourceCPFeature.ColumnValues ["PointId"]; } // BaseShape baseShape = sourceFeature.GetShape(); if ( baseShape is MultipolygonShape ) { ApproachMap approach = (ApproachMap)sourceFeature.Tag; MultipolygonShape mpShape = Projection.ConvertToInternalProjection(sourceFeature).GetShape() as MultipolygonShape; int polygonIndex = Convert.ToInt32(sourceFeature.ColumnValues ["PolygonIndex"]); Collection<vertex> lineEnds = new Collection<vertex>(); PolygonShape shape = mpShape.Polygons [polygonIndex]; RingShape rs = shape.OuterRing; if ( ptId == "Side1" || ptId == "Side2" ) { // // One of the side control points is selected to adjust width of a segment // // Extend side lines out to more accurately measure distance of target point from side of source CP lineEnds.Add(rs.Vertices [0]); lineEnds.Add(rs.Vertices [1]); LineShape side1Line = new LineShape(lineEnds); lineEnds.Clear(); lineEnds.Add(rs.Vertices [3]); lineEnds.Add(rs.Vertices [2]); LineShape side2Line = new LineShape(lineEnds); for ( int idx = 0; idx < 3; idx++ ) { side1Line.ScaleUp(100); side2Line.ScaleUp(100); } // Get closest points on extended lines PointShape psSide1 = side1Line.GetClosestPointTo(targetControlPoint, GeographyUnit.DecimalDegree); PointShape psSide2 = side2Line.GetClosestPointTo(targetControlPoint, GeographyUnit.DecimalDegree); // double distance = 0; bool addDistance = true; double sourceToSide1 = sourceControlPoint.GetDistanceTo(side1Line, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double sourceToSide2 = sourceControlPoint.GetDistanceTo(side2Line, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double targetToSide1 = targetControlPoint.GetDistanceTo(side1Line, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double targetToSide2 = targetControlPoint.GetDistanceTo(side2Line, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double distanceBetweenLines = Math.Round(side1Line.GetDistanceTo(side2Line, GeographyUnit.DecimalDegree, DistanceUnit.Meter)); if ( sourceToSide1 < sourceToSide2 ) { // // Source Control Point is on Side 1 // distance = psSide1.GetDistanceTo(targetControlPoint, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double distanceToOpposite = psSide2.GetDistanceTo(targetControlPoint, GeographyUnit.DecimalDegree, DistanceUnit.Meter); if ( ( distance > distanceToOpposite ) || ( distanceToOpposite < distanceBetweenLines ) ) { addDistance = false; } } else { // // Source Control Point is on Side 2 // distance = psSide2.GetDistanceTo(targetControlPoint, GeographyUnit.DecimalDegree, DistanceUnit.Meter); double distanceToOpposite = psSide1.GetDistanceTo(targetControlPoint, GeographyUnit.DecimalDegree, DistanceUnit.Meter); if ( ( distance > distanceToOpposite ) || ( distanceToOpposite < distanceBetweenLines ) ) { addDistance = false; } } // // Restore lines to original size // lineEnds.Clear(); lineEnds.Add(rs.Vertices [0]); lineEnds.Add(rs.Vertices [1]); side1Line = new LineShape(lineEnds); lineEnds.Clear(); lineEnds.Add(rs.Vertices [3]); lineEnds.Add(rs.Vertices [2]); side2Line = new LineShape(lineEnds); distance = Math.Round(distance); if ( distance > 0 ) { // slope of side lines double rise = rs.Vertices [1].Y - rs.Vertices [0].Y; double run = rs.Vertices [1].X - rs.Vertices [0].X; double angle = ( Math.Atan2(rise, run) ) * ( 180 / Math.PI ); // Ensure positive angle if ( angle < 0 ) { angle = angle + 180; } if ( addDistance ) { distance = Math.Min(distance, ( Coordinate.MAXTOLLERANCE - ( distanceBetweenLines - Coordinate.BUFFERLENGTH ) ) / 2); if ( distance > 0 ) { // // If going away from side, increase width // side1Line.TranslateByDegree(distance, ( ( 180 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); side2Line.TranslateByDegree(distance, ( ( 360 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); } } else { // // If shrinking approach, limit it to 30 meters and reduce width // if ( distanceBetweenLines - ( distance * 2 ) >= Coordinate.BUFFERLENGTH ) { side1Line.TranslateByDegree(distance, ( ( 360 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); side2Line.TranslateByDegree(distance, ( ( 180 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); } else { distance = Math.Round(( distanceBetweenLines - Coordinate.BUFFERLENGTH ) / 2); if ( distance > 0 ) { side1Line.TranslateByDegree(distance, ( ( 360 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); side2Line.TranslateByDegree(distance, ( ( 180 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); } } } } // // Save new size // Vertex [] newPoints = new Vertex [4]; newPoints [0] = new Vertex(side1Line.GetPointOnALine(StartingPoint.FirstPoint, 0)); newPoints [1] = new Vertex(side1Line.GetPointOnALine(StartingPoint.LastPoint, 0)); newPoints [2] = new Vertex(side2Line.GetPointOnALine(StartingPoint.LastPoint, 0)); newPoints [3] = new Vertex(side2Line.GetPointOnALine(StartingPoint.FirstPoint, 0)); PolygonShape ps = new PolygonShape(new RingShape(newPoints)); // Update approach shape mpShape.Polygons [polygonIndex] = ps; // // Update approach data // PointShape p1 = new PointShape(newPoints [0]); PointShape p2 = new PointShape(newPoints [3]); ( (Coordinate)approach.Coordinates [polygonIndex] ).Tolerance = Math.Min(Coordinate.MAXTOLLERANCE, (int) Math.Max(0, Math.Round(p1.GetDistanceTo(p2, GeographyUnit.DecimalDegree, DistanceUnit.Meter)) - Coordinate.BUFFERLENGTH)); } else if ( ptId.Equals("Tail") || ptId.Equals("0") ) { // // Control point on the front or tail is adjusted...move position of segment // PointShape front = null; PointShape tail = null; if ( ptId.Equals("Tail") ) { polygonIndex = mpShape.Polygons.Count - 1; shape = mpShape.Polygons [polygonIndex]; rs = shape.OuterRing; lineEnds.Clear(); lineEnds.Add(rs.Vertices [0]); lineEnds.Add(rs.Vertices [3]); front = new LineShape(lineEnds).GetCenterPoint(); tail = targetControlPoint; } else if ( ptId.Equals("0") ) { polygonIndex = 0; shape = mpShape.Polygons [polygonIndex]; rs = shape.OuterRing; lineEnds.Clear(); lineEnds.Add(rs.Vertices [1]); lineEnds.Add(rs.Vertices [2]); front = targetControlPoint; tail = new LineShape(lineEnds).GetCenterPoint(); } mpShape.Polygons [polygonIndex] = UpdateSegment(polygonIndex, front, tail, approach); } else // should be an index item { // // Control point between segments is being moved // // Adjust the first of the two altered segments // polygonIndex = Convert.ToInt32(ptId) - 1; shape = mpShape.Polygons [polygonIndex]; rs = shape.OuterRing; lineEnds.Clear(); lineEnds.Add(rs.Vertices [0]); lineEnds.Add(rs.Vertices [3]); mpShape.Polygons [polygonIndex] = UpdateSegment(polygonIndex, new LineShape(lineEnds).GetCenterPoint(), targetControlPoint, approach); // // Adjust the second of the two altered segments // polygonIndex = Convert.ToInt32(ptId); shape = mpShape.Polygons [polygonIndex]; rs = shape.OuterRing; lineEnds.Clear(); lineEnds.Add(rs.Vertices [1]); lineEnds.Add(rs.Vertices [2]); mpShape.Polygons [polygonIndex] = UpdateSegment(polygonIndex, targetControlPoint, new LineShape(lineEnds).GetCenterPoint(), approach); } mpShape = (MultipolygonShape)Projection.ConvertToExternalProjection(mpShape); ClearAllControlPoints(); // Update tooltip sourceFeature.ColumnValues ["Tip"] = approach.TipText; sourceFeature.ColumnValues ["EditTip"] = approach.EditTipText; returnFeature = new Feature(mpShape.GetWellKnownBinary(), sourceFeature.Id, sourceFeature.ColumnValues); returnFeature.Tag = sourceFeature.Tag; // Notify listeners OnApproachChanged(); return returnFeature; } returnFeature = base.MoveVertexCore(sourceFeature, sourceControlPoint, targetControlPoint); } catch ( Exception ) { returnFeature = sourceFeature; } return returnFeature; } /// <summary></summary>/// Update the segment according to the new location /// ///
<param name="polygonIndex" />Index into MultipolygonShape Polygons (segment index) ///
<param name="front" />PointShape of front of segment ///
<param name="tail" />PointShape of rear of segment ///
<param name="approach" />Approach being adjusted /// <returns>New PolygonShape representing the segment private PolygonShape UpdateSegment( int polygonIndex, PointShape front, PointShape tail, ApproachMap approach ) { Collection<vertex> lineEnds = new Collection<vertex>(); // slope of side lines double rise = tail.Y - front.Y; double run = tail.X - front.X; double angle = ( Math.Atan2(rise, run) ) * ( 180 / Math.PI ); // Ensure positive angle if ( angle < 0 ) { angle = angle + 180; } lineEnds.Clear(); lineEnds.Add(new Vertex(front.X, front.Y)); lineEnds.Add(new Vertex(tail.X, tail.Y)); LineShape centerLine = new LineShape(lineEnds); int tollerance = ((Coordinate)approach.Coordinates [polygonIndex]).Tolerance; double bufferWidth = Math.Truncate((double)( tollerance + Coordinate.BUFFERLENGTH + 1 ) / 2); LineShape side1 = (LineShape)centerLine.CloneDeep(); side1.TranslateByDegree(bufferWidth, ( ( 180 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); LineShape side2 = (LineShape)centerLine.CloneDeep(); side2.TranslateByDegree(bufferWidth, ( ( 360 - angle ) % 360 ), GeographyUnit.DecimalDegree, DistanceUnit.Meter); // // Save new size // Vertex [] newPoints = new Vertex [4]; newPoints [0] = new Vertex(side1.GetPointOnALine(StartingPoint.FirstPoint, 0)); newPoints [1] = new Vertex(side1.GetPointOnALine(StartingPoint.LastPoint, 0)); newPoints [2] = new Vertex(side2.GetPointOnALine(StartingPoint.LastPoint, 0)); newPoints [3] = new Vertex(side2.GetPointOnALine(StartingPoint.FirstPoint, 0)); // // Update segment X,Y offsets in approach data // foreach ( Feature intRadio in EditShapesLayer.InternalFeatures ) { if ( intRadio.ColumnValues.ContainsKey("Type") && intRadio.ColumnValues ["Type"].Equals("IntersectionRadio") ) { GeoPt offsets = MapHelper.PositionToOffset((PointShape)intRadio.GetShape(), front); ((Coordinate)approach.Coordinates [polygonIndex]).X = offsets.X; ((Coordinate)approach.Coordinates [polygonIndex]).Y = offsets.Y; offsets = MapHelper.PositionToOffset((PointShape)intRadio.GetShape(), tail); ((Coordinate)approach.Coordinates [polygonIndex+1]).X = offsets.X; ((Coordinate)approach.Coordinates [polygonIndex+1]).Y = offsets.Y; break; } } // // Update computed length of the segment // ( (Coordinate)approach.Coordinates [polygonIndex] ).MeterLength = Math.Round(centerLine.GetLength(GeographyUnit.DecimalDegree, DistanceUnit.Meter)); return new PolygonShape(new RingShape(newPoints)); } /// <summary></summary>/// Workaround so multipolygon will paint "invalid polygons" /// (overlapping sections sometimes don't paint) /// ///
<param name="canvas" />protected override void DrawCore( GeoCanvas canvas ) { // Draw 6 inmemoryLayers. Collection<simplecandidate> labelsInAllLayers = new Collection<simplecandidate>(); EditShapesLayer.Open(); Collection<feature> backedUpFeatures = new Collection<feature>(); // EditShapesLayer.QueryTools.GetAllFeatures(ReturningColumnsType.AllColumns); foreach ( Feature feature in EditShapesLayer.InternalFeatures ) { backedUpFeatures.Add(feature); } EditShapesLayer.InternalFeatures.Clear(); foreach ( Feature feature in backedUpFeatures ) { BaseShape baseShape = feature.GetShape(); if ( baseShape is MultipolygonShape ) { MultipolygonShape multiPolygonShape = (MultipolygonShape)baseShape; // // Paint individual polygons instead so that 'invalid' multipolygons paint // foreach ( PolygonShape polygonShape in multiPolygonShape.Polygons ) { Feature polygonFeature = new Feature(polygonShape, feature.ColumnValues); EditShapesLayer.InternalFeatures.Add(polygonFeature); } } else { EditShapesLayer.InternalFeatures.Add(feature); } } EditShapesLayer.Draw(canvas, labelsInAllLayers); canvas.Flush(); EditShapesLayer.InternalFeatures.Clear(); foreach ( Feature feature in backedUpFeatures ) { EditShapesLayer.InternalFeatures.Add(feature); } //EditShapesLayer.Close(); ExistingControlPointsLayer.Open(); ExistingControlPointsLayer.Draw(canvas, labelsInAllLayers); canvas.Flush(); //ExistingControlPointsLayer.Close(); //ResizeControlPointsLayer.Open(); //ResizeControlPointsLayer.Draw(canvas, labelsInAllLayers); //canvas.Flush(); ////ResizingControlPointsLayer.Close(); //RotateControlPointsLayer.Open(); //RotateControlPointsLayer.Draw(canvas, labelsInAllLayers); //canvas.Flush(); ////RotatingControlPointsLayer.Close(); DragControlPointsLayer.Open(); DragControlPointsLayer.Draw(canvas, labelsInAllLayers); canvas.Flush(); } #endregion overrides #region Protected methods protected void OnApproachChanged() { if ( ApproachChanged != null ) { ApproachChanged(this, new EventArgs()); } } #endregion Protected methods } //use in map... // // Set up edit overlay for editing of approach maps // ApproachInteractiveEditOverlay customEditOverlay = new ApproachInteractiveEditOverlay(); customEditOverlay.ResizeMode = ResizeMode.OnePointFixed; customEditOverlay.Projection = m_projection; customEditOverlay.ApproachChanged += new EventHandler(customEditOverlay_ApproachChanged); customEditOverlay.CanAddVertex = false; customEditOverlay.CanRemoveVertex = false; customEditOverlay.CanDrag = false; customEditOverlay.CanRotate = false; customEditOverlay.CanResize = false; customEditOverlay.ResizeControlPointsLayer.IsVisible = false; customEditOverlay.RotateControlPointsLayer.IsVisible = false; // Set up editing area style customEditOverlay.EditShapesLayer.Open(); customEditOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateHatchStyle( GeoHatchStyle.LightDownwardDiagonal, GeoColor.FromArgb(200, GeoColor.StandardColors.Magenta), GeoColor.FromArgb(150, GeoColor.StandardColors.Magenta), GeoColor.FromArgb(200, GeoColor.StandardColors.DarkBlue), 1, DashStyleToLineDashStyle(DashStyle.Dash), 0, 0); // Remove blue dot customEditOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimplePointStyle( PointSymbolType.Circle, GeoColor.SimpleColors.Black, 1); customEditOverlay.EditShapesLayer.Columns.Add(new FeatureSourceColumn("Name")); customEditOverlay.EditShapesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; customEditOverlay.EditShapesLayer.Close(); // Set up control point label style customEditOverlay.ExistingControlPointsLayer.Open(); customEditOverlay.ExistingControlPointsLayer.Columns.Add(new FeatureSourceColumn("Label")); TextStyle controlPtText = TextStyles.CreateSimpleTextStyle("Label", "Arial", 14, DrawingFontStyles.Regular, GeoColor.StandardColors.Blue, GeoColor.StandardColors.Green, 0, 0, 5); controlPtText.PointPlacement = PointPlacement.UpperCenter; // Add text style for displaying map point numbers customEditOverlay.ExistingControlPointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(controlPtText); // Change control point style to a larger point PointStyle ptStyle = ( (ValueStyle)customEditOverlay.ExistingControlPointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles [0] ).ValueItems [0].DefaultPointStyle; ptStyle.SymbolSize = 12; //ptStyle.SymbolType = PointSymbolType.Circle; //PointStyle valuePt2 = ( (ValueStyle)customEditOverlay.ExistingControlPointsLayer.ZoomLevelSet.ZoomLevel01.CustomStyles [0] ).ValueItems [1].DefaultPointStyle; //valuePt2.SymbolSize = 12; //valuePt2.SymbolType = PointSymbolType.Square; //valuePt2.PointType = PointType.Symbol; customEditOverlay.ExistingControlPointsLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; customEditOverlay.VertexAdding += new EventHandler<vertexaddingeditinteractiveoverlayeventargs>(EditOverlay_VertexAdding); m_map.EditOverlay = customEditOverlay;
David,
   I think I can help you on a few of these.
 The first one I am not quite sure and we are going to have to re-create it.  The code you have in the post seems garbled so would you mind attaching it as a text file?  Also when you post the code make sure you follow all the guidelines on posting code, it’s a sticky on all of the forums.  You need to make sure to use the editor and paste the code in the “Source View” otherwise it adds all kinds of html script tags.  If you did do all of this then ignore my comments and maybe something else happened.  For now try to attach it as a text file.  Actually one thing you might try is when you add the control point style and the label style try adding them to the CustomStyles property.  See if that fixes the issue.
 On the second point there is a way to do this.  What you need to do is override the MouseDownCore and inside of there look at the InteractionArguments that gets passed in.  On that object you will find a SearchingTolerance property.  The property is in world units so you need to make that larger, maybe double it to make it twice as big.  We calculate it based on 10 pixels but we do this in the Map itself as that is when we know the map width and the other information to do the calculation.  Just to reiterate the value is in world units and not pixels, we did the conversion outside of the overlay.  If you make that larger you should see an effect.  Make sure after you change that you call the base.MouseDownCore passing in the object you changed.
 For the third point this is probably a bug.  Could do try and after you remove all of the features to clear the control points by calling the EditOverlay.ExistingControlPointsLayer.InternalFeatures.Clear() method?  When you remove the features you can also try calling the CalculateAllControlPoints as well and see if this help you.  Let me know and we can start our debugging on this.  Sorry we wouldn’t do it sooner but we have the release to get out and staffing is tight this week.
Thanks for the quick reply.  I did try the Source/Paste method but evidently messed something up.  I am attaching it here.
For item1, the label text style is in the custom styles but hopefully the attached code can help.
For item 2, I will give this approach a shot.
For item 3, clearing the ExistingControlPointLayer features whenever I clear the EditShapesLayer features did seem to prevent the continuous panning.
1179-CustomEditOverlay.cs (27.3 KB)
David,
   Give us a day or two to test this.  We are pretty busy testing the new release to be rolled out and resources are a bit scarce for the next day or two.  Please post back to this message as once I post it will take it off our radar.  Our system just shows posts where a user and not support was the last one to post to it and we use that to manage the forums.
 I think you will find luck with the second item as it should work as I explained.
 On item three we need to find out why this happens as internally we should be calling the CalculateAllControlPoints and it should happen automatically.  No harm in you calling it but it is strange.
Posting back as requested.
David,
According to your requirements, we made a sample shown in attachment, hope it helps.
1205-Post6264_Sample.zip (10.5 KB)
