EllipseShape Innacuracy issues
Hi all,
I have produced a simplified example included below to show the behavior I am seeing in our application along with a picture showing the behavior. Essentially the tool I am working on needs to draw a circle given a point feature and a user defined radius. The test data I am using is a township grid where each of the grid squares is 6 miles by 6 miles. With the radius of the EllipseShape set to 3.0 and the units set to DistanceUnit.Mile I am seeing that that EllipseShape diameter is roughly 2/3 of the expected 6 miles as you can in the included image I clicked roughly in the center of the grid square. I have double checked our grid data for accuracy.
Any ideas on what might be causing this?
 private async void OnMapViewLoaded(object sender, RoutedEventArgs e)
     MapView.MapUnit = GeographyUnit.Meter;
     OpenStreetMapOverlay osm = new OpenStreetMapOverlay();
     MapView.Overlays.Add(osm);
     LayerOverlay testOverlay = new LayerOverlay();
     MapView.Overlays.Add("test overlay", testOverlay);
     Add3DTestLayer(testOverlay);
     MapView.MapClick += MapView_MapClick;
     MapView.CurrentExtent = new RectangleShape(-12620874, 6871071, -12553663, 6825972);
     await _mapView.RefreshAsync();
private async void MapView_MapClick(object sender, MapClickMapViewEventArgs e)
    AreaStyle areaStyle = AreaStyle.CreateSimpleAreaStyle(GeoColors.Transparent, GeoColors.Black, 1);
    InMemoryFeatureLayer clickLayer = new InMemoryFeatureLayer();
    clickLayer.Projection = new Projection(3857);
    LayerOverlay layerOverlay = new LayerOverlay();
    ZoomLevel selectionZoomLevel = clickLayer.ZoomLevelSet.ZoomLevel01;
    selectionZoomLevel.CustomStyles.Add(areaStyle);
    selectionZoomLevel.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
    clickLayer.InternalFeatures.Add(new Feature(new EllipseShape(e.WorldLocation, 3.0,   _mapView.MapUnit, DistanceUnit.Mile)));
    layerOverlay.Layers.Add(clickLayer);
    await _mapView.RefreshAsync(layerOverlay);
        private void Add3DTestLayer(LayerOverlay testOverlay)
            var test3DLayer = new FileGeoDatabaseFeatureLayer("C:/ProgramData/{redacted name township grid data}.gdb")
                FeatureSource =
                    ProjectionConverter = new ProjectionConverter(4269, 3857)
                ActiveLayer = "{REDACTED TOWNSHIP LAYER}"
            // Add the layer to the overlay we created earlier.
            testOverlay.Layers.Add("3D Test Data", test3DLayer);
            // Create a pen that we will use below.
            AreaStyle style = new AreaStyle(GeoPens.DimGray, new GeoSolidBrush(new GeoColor(64, GeoColors.ForestGreen)));
            // Create an Area style on zoom level 1 and then apply it to all zoom levels up to 20.
            test3DLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Clear();
            test3DLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(style);
            test3DLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Hi Sean,
What you’re seeing is actually expected once Web Mercator and projections get involved:
Web Mercator (EPSG:3857) distorts distance and area
In EPSG:3857, coordinates are in “pseudo-meters,” and does not preserve true ground distance or area. So a circle created as “3 miles” in Web Mercator space will not correspond to a perfect 3-mile radius on the earth’s surface, especially as you move away from the equator.
How to create a more accurate 3-mile circle
  1. Pick a local projected CRS for your area that uses meters and is designed for distance/area work (e.g., the appropriate UTM or State Plane zone, something like EPSG:269xx / 326xx depending on location).
  2. Reproject the click point into that local CRS.
  3. Construct the circle in local meters (convert miles → meters).
  4. Reproject the resulting geometry back to 3857 just for drawing.
On the map it may look slightly non-circular because of the projection, but the geometry itself will represent a true 3-mile radius on the ground.
Here’s a sample helper showing the idea (replace localEpsg with the correct EPSG for your region):
// 1) Choose an appropriate local projected CRS for your area (example only).
//    Replace 26915 with the EPSG that matches your local UTM/State Plane zone.
int localEpsg = 26915;
var sphericalMercatorToLocal = new ProjectionConverter(3857, localEpsg);
sphericalMercatorToLocal.Open();
private Feature GetCircleFeature(PointShape centerInWebMercator, double radiusInMiles)
    // 2) Project the clicked point from Web Mercator (3857) to the local CRS.
    var centerInLocal = (PointShape)sphericalMercatorToLocal.ConvertToExternalProjection(centerInWebMercator);
    // 3) Convert miles to meters (local CRS uses meters).
    double radiusMeters = radiusInMiles * 1609.344;
    // 4) Build the circle in local coordinates (width/height in meters).
    var ellipseInLocal = new EllipseShape(centerInLocal, radiusMeters * 2, radiusMeters * 2);
    var featureInLocal = new Feature(ellipseInLocal);
    // 5) Project the circle back to Web Mercator for display.
    var featureInWebMercator = sphericalMercatorToLocal.ConvertToInternalProjection(featureInLocal);
    return featureInWebMercator;
In your click handler you’d use this instead of constructing the EllipseShape directly in 3857
If you can’t use a local UTM projection, you can instead work in decimal degrees (EPSG:4326) and rely on geodesic (Haversine / great-circle) distance calculations. This won’t be as accurate as a good local projected CRS, but it’s usually acceptable if you don’t need survey-grade precision.
Excellent, Works great.
I figured I must be missing something projection related but wasn’t sure what.
Sean
That’s Awesome! :+1:
