Enabling AJAX on the map control
I have downloaded a 4.5 evalution version. I placed the map control within the ASP.NET update panel. Also I had a Map.Click event to test if the AJAX postback works. The postback is happensing but the Map does not render after the ajax postback completes.
Am I missing any settings for enabling the AJAX here?
Appreciate your help.
Hi Satish,
Please compare with the following link (which demonstrate how to enable ajax for asp.net 2.0 web application). Or you can provide us a self-contained sample to illustrate your issue, we'll check it for you.
geekswithblogs.net/ranganh/a...13446.aspx
Ivan
