Error attempting to use GeoSerializer
I have been looking forward to being able to use the new GeoSerializer class. We currently serialize maps to a binary format and every time we move to a newer build of MS Desktop none of our files will open anymore.
I tried the GeoSerializer but I get an error every time:
 System.ArgumentException was unhandled
  Message=Invalid name character in 'fRU='. The '=' character, hexadecimal value 0x3D, cannot be included in a name.
  Source=System.Xml
  StackTrace:
       at System.Xml.XmlWellFormedWriter.CheckNCName(String ncname)
       at System.Xml.XmlWellFormedWriter.WriteStartElement(String prefix, String localName, String ns)
       at System.Xml.XmlWriter.WriteElementString(String localName, String ns, String value)
       at System.Xml.XmlWriter.WriteElementString(String localName, String value)
       at ThinkGeo.MapSuite.Core.XmlSerializationFormatter.jDU=(GeoSerializationNode jTU=, XmlWriter jjU=)
       at ThinkGeo.MapSuite.Core.XmlSerializationFormatter.SaveCore(GeoSerializationNode node, Stream stream)
       at ThinkGeo.MapSuite.Core.GeoSerializationFormatter.Save(GeoSerializationNode node, Stream stream)
       at ThinkGeo.MapSuite.Core.GeoSerializer.Serialize(Object serializationObject)
       at SerializeProjectedLayer.Form1.SerializeShapefile() in C:\Users\steller\Documents\Visual Studio 2010\Projects\ThinkGeo\SerializeProjectedLayer\Form1.vb:line 58
       at SerializeProjectedLayer.Form1.btnSerialize_Click(Object sender, EventArgs e) in C:\Users\steller\Documents\Visual Studio 2010\Projects\ThinkGeo\SerializeProjectedLayer\Form1.vb:line 117
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at SerializeProjectedLayer.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
Here is the code that does attempts to serialize the layer:
   Private Sub SerializeShapefile()
      Dim oGeoSerializer As New GeoSerializer
      Dim oStream As FileStream
      Dim sFileName As String
      Dim oOverlay As LayerOverlay
      sFileName = GetUserFolder() & "Shapefile.wxd"
      '***** Open a file stream to use for serialization
      oStream = New FileStream(sFileName, FileMode.Create, FileAccess.Write, FileShare.None)
      oOverlay = CType(WinformsMap1.Overlays(0), LayerOverlay)
      If oOverlay.Layers(0).IsOpen Then
         oOverlay.Layers(0).Close()
      End If
      oGeoSerializer.Serialize(oOverlay.Layers(0))
      oStream.Close()
   End Sub
We are using build 5.5.24.0. I have attached a sample project to make it easy to reproduce.
Steve
SerializeProjectedLayer.zip (317 KB)
Steve,
 Thanks for your post and sample application!  We are glad to hear you are trying out the new GeoSerializer class and agree with you that this will be a much better solution than Binary serialization going forward.
 After looking at your sample I was able to get the layer to serialize using the daily build version from today 5.5.25.0 by modifying the line of code below in the SerializeShapefile function from:
 To:
 oGeoSerializer.Serialize(oOverlay.Layers(0), oStream)
 I know there is still active development going on with this class so it’s quite possible that this method signature changed from 5.5.24.0 to 5.5.25.0.  After making this change I was able to verify that the serialization did occur because I opened up the Shapefile.wxd file in notepad and saw the XML.
 The bad news is that when I went to deserialize the file back into the layer I get an InvalidCastException.  I will go ahead and share your sample with the development team working on this class and see if they can provide some guidance.   Once I hear back from them I will update the post.
Clint,
 Thanks for the reply. I’ll keep an eye on this topic.
 Steve
No problem Steve, I will update this thread once I hear back.
Hi Steven,
I just tested the sample with the latest version 5.5.38.0, it worked fine, it didn't throw the "invalid character" exception.
Just modify the sample code as Clint suggested, then you are good to go.
Please note that GeoSerializer is still under development, there may still be other potential bugs.
Please let us know if you have any further questions.
Tsui
