When attempting to use MapSuite Routing Explorer with MNlkaA40.shp from the world map kit 5.0 files I am getting the following error:
What do I need to do to get the routing index for the mn level 40 roads?
Hi Jake,
We have tried to build the Rtg files by using MapSuite Routing Explorer with MNlkaA40.shp under both decimal degree and meter. Both of them can be generated without any exception. So would you please get the latest version for MapSuite Routing Explorer and then have a try.
BTW, is there any other shape files in world map kit encountering the same issue or just this one have the issue? if the MNlkaA40.shp is the only one encountering this issue, I guess we can send the rtg file for you via email.
Best regards,
Thanks Johnny,
That is the only file that had the issue, I am not sure what was wrong with it. I reinstalled the entire world mapkit again and this time the file was able to generated. If I run into it again I will let you know. Right now it appears the issue was my local file was not the same as the one from the original world map kit.
Hi Jake,
Ok, it seems a good news. I guess the file might be modified in the past.
If the exception persists in the latest wmk files, please let us know.
