Error by loading a Oracle Spatial Layer
I have a problem when opening an Oracle Spatial layer. I use Oracle Spatial 10g, and get the following error:
ORA-13199: 3D geometries are not supported by geometry WKB / WKT generation.
ORA-06512: at "MDSYS.MD", line 1723
ORA-06512: at "MDSYS.MDERR", line 17
ORA-06512: at "MDSYS.SDO_UTIL", line 2415
ORA-06512: at "MDSYS.SDO_GEOMETRY", line 30
Now it may be me; but I'm sure that the data is not 3D. TatukGIS (we use it now) works fine.
The code below is what I've tried (the geometry is of type point):
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        WinformsMap1.MapUnit = GeographyUnit.Meter
        WinformsMap1.BackgroundOverlay.BackgroundBrush = New GeoSolidBrush(GeoColor.GeographicColors.ShallowOcean)
        Dim connectString As String = "User ID=testgv1;Password=test123;Data Source=DQ-OR:1521/LDORP;"
        Dim oracleLayer As New OracleFeatureLayer(connectString, "GBI_BOOM", "BOOM_ID")
        Dim proj4Projection As New Proj4Projection()
        proj4Projection.InternalProjectionParametersString = proj4Projection.GetEpsgParametersString(28992)
        proj4Projection.ExternalProjectionParametersString = proj4Projection.GetEpsgParametersString(28992)
        oracleLayer.FeatureSource.Projection = proj4Projection
        oracleLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.Capital1
        oracleLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        oracleLayer.Open()
        Dim staticOverlay As New LayerOverlay()
        staticOverlay.Layers.Add("BOMEN", oracleLayer)
        WinformsMap1.Overlays.Add(staticOverlay)
        WinformsMap1.CurrentExtent = oracleLayer.GetBoundingBox
        WinformsMap1.Refresh()
    End Sub
Is my problem too difficult?
Hi Hans,
 Sorry we cannot reproduce that.
 This exception should thrown by Oracle or NTS, we don’t have this exception related code.
 I google and found someone get same exception: kr.forums.oracle.com/forums/thread.jspa?messageID=3708662
 Here we have another topic related with this: gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/12/afv/topic/aft/6836/Default.aspx
 I am not sure whether that’s helpful, but I think maybe you can try to build some very simple data and try again for make sure whether that’s thrown by database and we can make sure the research direction.
