Error getting image properties
I have two applications and am using the following method in both
        Dim IconPath As String = Get_GIS_Icon(Unit_Name)
        If System.IO.File.Exists(IconPath) = False Then
            IconPath = AppPath & "\icons\gis\base.png"
        End If
        gisMap.Overlays("iconOverlay").Lock.EnterWriteLock()
        Dim myFeature As New Feature(Lon, Lat, Unit_Name)
        Try
            Dim myMapShape As New MapShape(myFeature)
            myMapShape.ZoomLevels.ZoomLevel01.DefaultTextStyle.TextColumnName = "Unit_Name"
            myMapShape.ZoomLevels.ZoomLevel01.DefaultPointStyle = New PointStyle(New GeoImage(IconPath))
            myMapShape.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
            Dim Y As Integer = myMapShape.ZoomLevels.ZoomLevel01.DefaultPointStyle.Image.GetHeight()
NOTE - Y is to get the offset for the label attached to the mapshape
The first works fine with
the second fails at that point and I have to do
            Dim myImage As New Bitmap(IconPath)
            Dim Y As Integer = myImage.Height
I have compared the propeties of myMapShape in both and they look the same
Any ideas
Ewan
Ewan,
When we wrote some code based on your code like this:
MapShape mapShape1 = new MapShape(new Feature(-104, 42));
mapShape1.ZoomLevels.ZoomLevel01.DefaultPointStyle = new PointStyle(new GeoImage(@"..\..\Data\Cargo Plane.png"));
mapShape1.ZoomLevels.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
mapShapeLayer.MapShapes.Add("1", mapShape1);
int y = mapShape1.ZoomLevels.ZoomLevel01.DefaultPointStyle.Image.GetHeight();
mapShape1.ZoomLevels.ZoomLevel01.DefaultPointStyle.YOffsetInPixel = y;
It works fine. So can you send us a small sample which is like your second application so that we can recreate the problem and to see how to solve it.
Any more information is appreciated.
sun
