Error in WPF but not in VS2008
Hi, i discovered a strange behavior when using Mapsuite Desktop in WPF. i created a TabControl, each tab should represent different map layouts.
When i run it using Expression Blend (pressing F5), the map is displayed. Try dragging the map or zoom in/out using mouse wheel several times, an error occur: "Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and attempt to cotinue". But when i use VS2008 to run the exact same program, no matter how i drag or zoom in/out, no error occur.
i then tried to put the map in StackPanel or a Grid, using Blend to run, the same error occured.  Using VS2008, no error. Is there something that must be configured in Blend?
Ric
Ric,
 Could you check whether you are using the latest version or send a demo to us as we could not recreate it in version 3.0.199.
 ThinkGeo Support
