At the moment we are migrating our applications from ThinkGeo 10.x to 13.0.1. In principle it works fine but we observe an error when we close the window which contains the map and reopen it. This error message did occur with ThinkGeo 10.x.
The error message is
The specified element is already the logical child of another element. First perform a separation.
bei System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
bei System.Windows.FrameworkElement.AddLogicalChild(Object child)
bei System.Windows.Controls.UIElementCollection.AddInternal(UIElement element)
bei ThinkGeo.Core.MapViewBase.WUs=(Object sender, AddedGeoCollectionEventArgs e)
bei ThinkGeo.Core.GeoCollection`1.OnAdded(AddedGeoCollectionEventArgs e)
bei Rwe.Core.Map.TG.Services.Map.MapManager.ZeigeKarte(KARTEN_KONFIG kartenkonfig) in D:\Agents\Agent_5_work\8\s\dotnet\core\Map\ThinkGeoV2\Services\Map\MapManager.cs:Zeile 1526.
and occurs when we try to add an overly by follwing code
mapView.Overlays.Add( maplayer.Overlay );
The variable mapView is an instance of MapView.
Did anyone observe a similar behaviour and know what to do?
With best regards
Peter
