Error message with wpfgeoimage to set the style of a point
Hi ,
If we define a style to represent a point as  :
new PointStyle(new WpfGeoImage(new Uri(“pack://application:,/Test.UI;component/Images/Icon3.png”)));
and the icon3.jpg is defined as a resource, there is an error message :
L’exception System.ArgumentException n’a pas été gérée
  HResult=-2147024809
  Message=Image from image path: is missing or invalid.
  Source=WpfDesktopEdition
  StackTrace:
       à ThinkGeo.MapSuite.WpfDesktopEdition.Tile.<>c__DisplayClass6.<DrawException>b__4()
       à System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       à MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
       à System.Windows.Threading.DispatcherOperation.InvokeImpl()
       à System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       à System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       à System.Windows.Threading.DispatcherOperation.Invoke()
       à System.Windows.Threading.Dispatcher.ProcessQueue()
       à System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       à MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       à MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       à System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
       à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
       à MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
       à System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
       à System.Windows.Application.RunInternal(Window window)
       à System.Windows.Application.Run()
       à Test.Tests.App.Main() dans C:\Steph_MainTFS\Main\Test.Tests\obj\x86\Debug\App.g.cs:ligne 51
       à System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       à Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       à System.Threading.ThreadHelper.ThreadStart()
  InnerException:
The version dll used is 8.0.103.0.
Can you reproduce this error message ?
Are we making a mistake when we define the style of the point with wpfgeoimage ?
Thanks for your help.
Regards.
Steph.
Hi Steph,
From the description of exception, seems like there should
be something with the image path or the WpfGeoImage, I guess it’s hard for us
to determine the problem just based on it, would you please attach the code of
WpfGeoImage here? Or please send it to forumsupport@thinkgeo.com?
HI Johnny,
I joined an example with WpfGeoImage.
The version of dll is 8.0.103.0.
  1. The zip file is the project
  2.
  3. The screenshot is to see the project organization.
Regards.
Steph.
WPFThinkgeo_Test1.zip (3.05 KB)
Hi Steph,
Thanks for your demo, the WpfGeoImages is used with WpfGeoCanvas and DrawingVisualGeoCanvas for EditInteractiveOverlay and TrackInteractiveOverlay, but PointStyle uses GDI+ for drawing, please try the code as following:
 m.ZoomLevelSet.ZoomLevel01.DefaultPointStyle
= new PointStyle(new GeoImage("…/…/icon3.png"));
Hi Johnny,
 I tested WpfGeoimage because it was possible to use a uri, which is not the case with GeOimage.
 Regards.
 Steph.
Hi Steph,
 Like Johnny mentioned the reason, we can’t specify the WpfGeoImage as GeoImage, as for the Uri, I think there is another way to get geoimage from an uri:
private GeoImage GetGeoImage(Uri imageUri)
            // return new GeoImage(Application.GetRemoteStream(imageUri).Stream);
            return new GeoImage(Application.GetContentStream(imageUri).Stream);
 Hope it helps.
