In my application on map loading with all layers in Albers Equal area projection I am getting very generalize error. I have attached screenshot below.
Request you to guide when this type of error occur.
Goral
Goral
Hi Goral,
From your exception, it shows “out of memory” when draw polygon.
I think that’s related with your running machine environment, please check the memory usage.
Then run your application in some other test machine to compare the behavior.
You can also build a simple project to help you locate which reason cause the exception.
Wish that’s helpful.
