I am new to ThinkGeo. I had a test VS VB application that would show the locations of all our vehicles based on their Latitudes and Longitudes. The application worked fine last month. I went back to it today to do some more work and it throws and error when I do a Map.Refresh command. Absolutely nothing has been change since it was last use a month ago. The Try/Catch error message is: “One or more errors occurred.” I use Window Forms NOT WPF. Any help would be appreciated. And if possible just don’t point me an example file, they’re all crap and never work.
Also, the TG Product Center has the following showing as activated: Desktop for Winforms, World Streets, and Routing. The Geocoder is showing as expired. If I’m placing markers on the map based on Lat/Lon would I need the GeoCoder??
