Hello, I have a problem when I run an example from MapSuite. I want to see a nautical Chart S-57, but when I run the example, the error in the image appear. I don´t have any idea what is this error or how to solve it. Anyone can help me? Or is there any other way to visualize this kind of file?
Error on MapSuite Nautical Charts Viewer, running an example
Hi Alberto,
That should because you hadn’t reference the correct dll.
If you are using V10, please update you dll via NuGet.
If you are using V9, please make sure your MapSuiteCore and your WpfEdition is both using Development edition or Release edition, if one of them is Release and the other is Development, you will met this problem.
Please let us know if that still hadn’t been solved.
