I'm currently testing Map Suite Web Edition.
When trying to add a map component, I got this issue :
Parser Error Message: Cannot create an object of type 'ThinkGeo.MapSuite.Core.ZoomLevelSet' from its string representation 'ThinkGeo.MapSuite.Core.ZoomLevelSet' for the 'ZoomLevelSet' property.
the code in my aspx page is the following:
cc1:Map ID="Map1" runat="server" CurrentScale="NaN" Cursor="Default"
Height="100%" Width="100%"
ZoomLevelSet="ThinkGeo.MapSuite.Core.ZoomLevelSet"
/cc1:Map
I removed the other "properties" in order to have the minimum only.
I have also to inform that I removed the following code :
asp:ScriptManager ID="ScriptManager1" runat="server" /asp:ScriptManager, because, my page containing my Map component inherits of another "template" page, which already instantiatse the ScriptManager code, and if I leave it, there is an error saying that only one instance of ScriptManager is possible.
Does anybody have an idea how to solve this "basic" problem ???
Thank you
