Hi Guys,
I’ve been working on a utility to convert GPX files to Shapefiles. When the GPX layer is opened, sometimes I get an exception:
“An item with the same key has already been added.”
I took a closer look at the GPX file contents and found there were multiple links defined right after the opening tag for the track:
<trk>
<name>Jura Route 7 / 2011 on GPSies.com</name>
<link href=“http://www.gpsies.com/map.do?fileId=klbbhppyykgoeivn”>
<type>trackOnWeb</type>
</link>
<link href=“AllTrails: Trail Guides & Maps for Hiking, Camping, and Running | AllTrails”>
<type>elevationChartUrlMap</type>
</link>
<type>elevationChartUrlMapThumb
</link>
<type>elevationChartUrlTab
</link>
It looks like the GPX layer is trying to create multiple columns with the name ‘link’, I believe that is what is causing the error.
I have attached the file so you can have a look.
Steve
JuraRoute72011.zip (22.7 KB)
