Error using DrawSample method of TextStyle
I just installed the full version of  5.0 and noticed that the DrawSample method has been overloaded and the overload I am using has been deprecated. Now, in addition to providing a Canvas object, a DrawingRectangelF must also be provided. But now when I use this method I get the following error:
System.ArgumentException was unhandled
  Message=The parameter you supplied may not be empty.
Parameter name: text
  ParamName=text
  Source=MapSuiteCore
  StackTrace:
       at mBQ=.eTw=.7zw=(String 8Dw=, String 8Tw=)
       at ThinkGeo.MapSuite.Core.GeoCanvas.DrawText(String text, GeoFont font, GeoBrush fillBrush, GeoPen haloPen, IEnumerable`1 textPathInScreen, DrawingLevel drawingLevel, Single xOffset, Single yOffset, Single rotateAngle)
       at ThinkGeo.MapSuite.Core.TextStyle.DrawSampleCore(GeoCanvas canvas, DrawingRectangleF drawingExtent)
       at ThinkGeo.MapSuite.Core.Style.DrawSample(GeoCanvas canvas, DrawingRectangleF drawingExtent)
       at MapUtilities.DisplayUtilities.GetStyleImage(Style oStyle, Size oSize) in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Classes\DisplayUtilities.vb:line 96
       at MapUtilities.frmLayerProperties.mUpdateTextPreview() in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 915
       at MapUtilities.frmLayerProperties.mSetCurrentTextStyle() in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 489
       at MapUtilities.frmLayerProperties.mSetFormForFeatureLayer() in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 131
       at MapUtilities.frmLayerProperties.frmLayerProperties_Load(Object sender, EventArgs e) in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Forms\frmLayerProperties.vb:line 93
       at System.EventHandler.Invoke(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
       at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
       at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
       at System.Windows.Forms.Control.set_Visible(Boolean value)
       at System.Windows.Forms.Application.RunDialog(Form form)
       at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
       at System.Windows.Forms.Form.ShowDialog()
       at MapUtilities.LayerUtils.SetLayerProperties(SilvicsTOCNode oNode, CustomWinformsMap oMap, Boolean& bTOCUpdateNeeded) in C:\Silvics\VS 2010 Projects\GeoFrame\MapUtilities\Classes\LayerUtils.vb:line 1169
       at GeoFrame.frmMain.mHandleFrameworkToolClick(ToolBase oTool) in C:\Silvics\VS 2010 Projects\GeoFrame\GeoFrame\Forms\frmMain.vb:line 942
       at GeoFrame.frmMain.ToolbarsMgr_ToolClick(Object sender, ToolClickEventArgs e) in C:\Silvics\VS 2010 Projects\GeoFrame\GeoFrame\Forms\frmMain.vb:line 820
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
       at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
       at Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick()
       at Infragistics.Win.UltraWinToolbars.ToolMenuItem.OnClick()
       at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.DoClickProcessing(MouseEventArgs e)
       at Infragistics.Win.UltraWinToolbars.PopupMenuItemUIElement.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.TextUIElementBase.OnMouseUp(MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
       at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
       at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
       at Infragistics.Win.UltraWinToolbars.PopupControlBase.OnMouseUp(MouseEventArgs e)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.Run(ApplicationContext context)
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       at GeoFrame.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
  InnerException:
The text parameter it is complaining about is within the ThinkGeo codebase, so this looks like a potential bug.
Steve
Hi Steve,
 We are glad to hear that you are interested in our new v5.0.
 It looks your exception should be thrown from some API like DrawTextWithScreenCoordinate but not from DrawSample.
 I am not sure how you build the DrawingRectangelF and caused this issue, could you paste some code show how you call the APIs or provide us a small sample for reproduce that?
Hi Don,
Thanks for your reply. Here is a code sample.
oTextStyle = CType(oStyle, TextStyle)
oCanvas.BeginDrawing(oBitmap, oCanvasRect, GeographyUnit.Meter)
Dim oDrawingRectangle As DrawingRectangleF
oDrawingRectangle = oCanvas.MeasureText("Text Sample", oTextStyle.Font)
oTextStyle.DrawSample(oCanvas, oDrawingRectangle)
oCanvas.EndDrawing()
The error happens when the DrawSample method is called. At first I was trying to create the DrawingRectangleF using its constructor. I then saw somewhere in the forum where the MeasureText method was used to obtain it, so I switched to that method but no luck. Remember, this code works just fine with the deprecated method, which has no DrawingRectangleF parameter.
Steve
Dear Steven,
 Sorry to make you confused, the drawSample method is just designed to test if the textstyle is working, so we changed it, make it work for the LegendItem, the rectangel is not what you thinking, it decide the location in a big canvas, don’t worry it.
 If you want to keep use the old DrawSample, we can just keep it.
